6DOF sim / linear actuator diy / sabertooth-arduino
Discussion in 'DIY Motion Simulator Projects' started by baykah, Dec 12, 2016.
  1. Flymen
    Montreal, Canada
    2,479Coins
    DC motor, 6DOF
    Merci Baykah!
    Q-Est ce que tes petites billes a l'interieur du top bearing laissent des marques sur l`exterieur de la tige de carbone a long terme ... assez pour changer pour un Bushing IGUS ?
    J' ai les memes problemes ... ballscrew chinoise un peu courbé et je vais devoir ajouter le fameux spacer au bout de la tige comme celui de pmvcda
    The small bearing inside in your top ball bearing print some marks on the outside of the carbon rod in the long term ... enough to change to an IGUS Bushing?
    I have the same problems ... Chinese ball screw are little curved and I will have to add the famous spacer at the end of the rod like : pmvcda
  2. baykah
    baykah Active Member
    Toulouse - France
    414Coins
    I took carbon tube of 2mm thick (25/21mm) to be sure they are strong. The mark on mine are light, it is also producing small carbon dust arround.
    For DYI thing I don't think it is so much of a problem.
    Anyway, the igus are expensive.
    I'm more focused on removing the potentiometers .. they will fail long before the rod.
  3. baykah
    Toulouse - France
    414Coins
    I just bought a 10 turns position sensor from bourns
    AMM20B5A1CLASL380
    it costs arround 35€, it is contactless and output 0 to 5V on 10 turns.
    I will mount one in one of my actuators to validated things and switch the others after that.
    Goal is to go contactless to replace the potentiometers.
  4. Zwodog
    Zwodog New Member
    Austria
    65Coins
    Motion platform
    Hello. Sorry to interupt. Question from the absolute beginner. Just wondering. As position sensors look quite complicated. I might have missed out the topic in the faq. Did or anybody consider using a analog output IR proximity sensor like sharp GP2Y0A02YK0F instead of pods, belts and so on?
  5. baykah
    Toulouse - France
    414Coins
    I didn't see anyone try it but it might work
    According to the datasheet :
    "Distance Measuring Sensor Unit Measuring distance: 20 to 150 cm Analog output type"
    But the graph voltage vs distance is non linear, so it would need a correction within the arduino
    The version 10-80cm maybe more suited, however the non linearity is still the same
    http://www.sharp-world.com/products/device/lineup/data/pdf/datasheet/gp2y0a21yk_e.pdf
    It is not so expensive !, you would need to mount it on top of the actuator to avoir having dust on it.
    If I had time ....
  6. Flymen
    Montreal, Canada
    2,479Coins
    DC motor, 6DOF
    good , let me know if this work good ! ( laisse moi savoir si cela fonctionne bien ) merci , thanks
  7. CBC_North
    CBC_North Member
    Computer Engineer
    Ottawa, Canada
    334Coins
    Edit: Disregard the question. I found the FAQ section on battery protection which indicates I can use a bridge rectifier.
    I'm having the same issue as you did with the sabertooth tripping my server power supplies even with voltage clamping resistors. I'm going try to isolate the supplies with a diode and capacitor like you did. Is there a special type of diode that I should buy?
  8. baykah
    Toulouse - France
    414Coins
    I don't know, I just took one a big one :D
  9. SilentChill
    20,604Coins
    Hows it working, I have these in my basket at farnell for over a year lol Im upgrading to 24v soon so I will be getting either these or encoders but encoders are really expensive.
    @Thanos did a pretty cool 3D printed housing with a spring dunno if you have seen it or not ? https://www.thingiverse.com/thing:1926226
  10. baykah
    Toulouse - France
    414Coins
    I'm in the middle of rig disassembly (moving it in the house) I plan to do some maintenance on it in the mean time (and a little bit of paint).
    I will modify 1 actuator with the contactless position sensor asap, but I don't go as fast as I want ...
    I will be able to test without load, I strongly beleive it will work fine.
    I took a look at your link, it is great, removing the belt on my actuator would be great ...
  11. Thanos
    Electronics Engineer
    2,917Coins
    If i would look in to making more of these I'd be using kevlar string. Do google search for "Retracting ID Badge / Key Reel with Retractable Kevlar Cord"
  12. baykah
    Toulouse - France
    414Coins
    Yeah, pray not to broke everything if the wire get loose ..
  13. baykah
    Toulouse - France
    414Coins
    @SilentChill, I'm currently re assembling the sim and I tested one of my actuator (not ingame yet) with the AMM20B5A1CLASL380, so far so good.
    Next month I'll buy 2 more
  14. SilentChill
    20,604Coins
    Thanks for letting me know :) I am going the encoder route for my next build ;)
  15. baykah
    Toulouse - France
    414Coins
    @SilentChill
    The logic is to "home" the rig during starting ? and use the encoder for relative movement ?
    You put the encoder on the motor shaft directly ?
    Any idea of the cost of encoders ?
  16. SilentChill
    20,604Coins
  17. baykah
    Toulouse - France
    414Coins
    Some update :
    => I added a plate at the end of the motors to block them to ease the work of the front plate supporting everything.
    I did that because I found 3 motor support broken when doing a complete maintenance of the actuactors ..
    They would move before, now it is a tight fit
    => I added one contactless position 10 turn on one of the six to test
    => I painted the chassit :D
    => I did an enclosure + cooling for the arduino + sabertooth and I redone my wiring of the power supply to look like ... let's say ... not a complete mess.
    => modify an old part to fit a tablette mount on the motor shaft when not using the rig in car mode !
    Next is :
    More paint
    Better USB management ...
    Buy more contactless encoders ... (36€ each :/)
    Take a look on G seat (I allready have an arduino for the harness tensionner)
    I should be able to play again soon !
  18. baykah
    Toulouse - France
    414Coins
    Rebuild finished for now, I started working on the flypt interface ! Sor far, I like it but I have to redo most of my settings !
    I have 2 actuators that vibrate a lot ... culprit is most likely the low quality ballscrew from china .. I added during the rebuild, the anti woble V2 part, more tight fit inside the carbon tube, but it will not unbend the ballscrews ..
    I also changer the wood part, that was used to simulate the brake disk, and putted a strong flexible polymer in order to have a better felling during braking (a little more displacement)
