ROLL UP ROLL UP OCULUS SENSOR WORKS ON THE MOTION PLATFORM AGAIN !!!
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by SilentChill, Dec 16, 2018.
  1. SilentChill
    20,601Coins
    At least it did for me for about 20 laps please can anyone else try and see if it does or was i really lucky ?
  2. SeatTime
    Will give it a go later today, although one day I will have a new Pimax, still only a couple of thousand backer in front of me :):rolleyes:
  3. SilentChill
    20,601Coins
    Do you have an estimated time scale for delivery or is it just wait and see ? Look forward to your views on it whenever you do get it.
    153,920Coins
    +11,156 / 57 / -2
    Pimax said the majority of backers would get their HMD by Xmas, but given they are only around the 500 mark realistically that is not going to happen, mine is about mid 4000 in the que :(
  5. SeatTime
    Yes, their estimates are wrong to the point of concerning, considering this is not the first product they have released (Pimax 4K).
  6. dododge
    dododge Active Member Gold Contributor
    854Coins
    I'm in the 5000s and I think the kickstarter goes at least into the 7000s, not to mention the original delivery estimate was February 2018 :rolleyes:. So yeah, you can basically ignore anything they say regarding production and delivery timelines. They've even started(?) taking orders from regular consumers with some, uh, "optimistic" promises about delivery dates for those, too. It'll show up when it shows up but don't make any plans around it.
  7. anton_Chez
    anton_Chez Member
    445Coins
    Backer 4200 or so here, patiently waiting for mine to arrive.....
    For a year :grin
  8. Brass Yeti
    Brass Yeti All show - No go
    331Coins
    This has gone a little off topic. Can anyone else confirm what SilentChill has experienced? SilentChill is it still working for you?
  9. SilentChill
    20,601Coins
    Yeah I just have the occasional recentre issue but I'd say 95% it's working well.
    If you look at my last few YouTube videos they are all with the camera on the rig
  10. Brass Yeti
    331Coins
    Just tried it myself... It's a no go for me. I kept jumping around in the virtual cockpit every couple of turns.
  11. SilentChill
    20,601Coins
    I have also only have 1 camera connected and my touch controllers are not connected don't know if that helps or not and the camera is at the same height as my rift.
  12. SeatTime
    My camera is at head height, off to one side and around 30 centimeters from the Oculus Headset array, works well.
  13. Grumpher
    Grumpher New Member
    30Coins
    Can anyone else confirm with 6DOF and single sensor rig mounted that this works?
  14. sam poole
    sam poole Active Member
    midlands
    31Coins
    Have tried with mine and works well most of the time sometimes jumps up and down though possibly the sensor juddering
  15. sam poole
    midlands
    31Coins
    I had this but was OK after repositioning sensor
  16. Grumpher
    Grumpher New Member
    30Coins
    Just need to be sure because i'm managing the software systems for a commercial motion racing rig, updating could have side effects but if it fixes the auto centering issue than i'd be willing to give it a shot.
    How did you position the sensor to get it to work?
  17. sam poole
    midlands
    31Coins
    the problem I think could have been down to my arms getting in the way so i put it just below head height the opposite side of the gear stick about 60cm from headset
  18. Grumpher
    Grumpher New Member
    30Coins
    Just tried the latest version, no change. still bobbing up and down
  19. Brass Yeti
    331Coins
    I have a 3dof and my movements not not super dramatic, but I have found success with this method for the last few weeks. It does go out of center once in a while, but by remapping the recenter to a button makes it fine enough for me. Sensor is mounted head height about 2-3 ft away directly in front of me.
