80/20 Aluminum profile 2DoF build.
Discussion in 'DIY Motion Simulator Projects' started by Watchumacallit, Dec 12, 2018.
  1. Watchumacallit
    Watchumacallit BMET- Lead
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Starting my first DIY motion sim build. Hope I don't screw anything up too badly. I want to Thank @noorbeast for answering my noob questions and @Kranky Pantz for sharing his parts list and also answering my questions.
    Originally I wanted to build a motion platform like @Erwan960 as I have a similar rig as his but I was afraid my OSW and pedals where going to be too heavy. So decided to go with a seat mover instead.
    Ordered my motors and U joint(Yea, it was painted green by seller for some odd reason) from PGSaw ebay store and some more aluminum profiles. Drilled holes on mounting plates to accommodate profiles.
    Had to dis assemble one of the gearbox to turn shaft around.
    Dis assembly of the rig and mock up. Got L brackets for motor mounts from local hardware store.
    Will soon drill holes on brackets and attach motors and chair to frame.
    Completed Build!
    IMG_2372.jpg IMG_2371.jpg IMG_2370.jpg IMG_2369.jpg IMG_2368.jpg IMG_2366.jpg
    F576E0AB-93A6-4CB7-9512-516871B7F4F6.jpeg 24A15C49-1842-4E82-9271-39721B278BBA.jpeg D61DC9F1-7BB4-42F6-A5AC-E1BB9509ABBC.jpeg
    • Optimistic Optimistic x 1
    • Old Old x 1
  2. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,288Coins
    Woohoooooo!!!!!!
    And so it begins......
    Congrats, and I hope that everything moves along smoothly for you.
    Am I seeing that right, are you using a TM Alcantara 599xx Evo rim on your OSW wheelbase???
    Did you make a custom mounting ring or something, and also...do the buttons work????
    Pretty slick!!!
    PS No thanks needed, it's been a pleasure conversing with you, and don't forget that I'm just as much of a newb at this as you are...only with a 3 month head-start.
    I'm looking forward to watching this build come together. :popcorn
    Cheers!!! :cheers
  3. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Hey Kranky,
    How is everything? Got the rig tuned in?
    Yea, that is a TM wheel on my OSW. I got it from Ricmotech. It was on sale at the time and was too good to pass up. The buttons do work and it is OK for the price. I say that because there is a little flex on the wheel. Not noticeable though when racing but when i crank up the power on the OSW it can't handle it. Might invest on a better wheel after the build.
    and hey, thanks again for your help!
  4. Kranky Pantz
    Canada, Eh!
    1,288Coins
    Everything is going well, thanks.
    Yes, the rig is performing as I had hoped, and the tuning is going great.
    I just keep hammering away at testing a new plugin once I get the previous one functional.
    The Crew 2 just went free to play on Steam from now until the the end of the weekend, so I'm downloading it now and will be testing out that new Destruction Derby mode.
    It should be fun, and since the Wreckfest plugin no longer works now I'll be able to get my arcade-type of racing fix when the urge strikes.
    If it all goes well then I'll buy it because it's also on for 67% off...so there's no risk due to the free trial period, win-win!!!
    I use that same exact 599xx rim on my setup, really like it for what it is.
    Someday I'll upgrade, but it does the job for now and is probably the best TM rim in their lineup, aside from the F1 which is a nice contrast to also have on hand.
    Your build is looking fantastic so far, and it looks like you're off to a great start.
    Cheers!
  5. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Seat and motors mounted.
    Was going to put motors under seat but not enough height. Didn't want to go too high as my wheel deck and pedals will end up being too low.
    Turned motor around and will face levers backward toward the motors.
  6. Kranky Pantz
    Canada, Eh!
    1,288Coins
    Lookin' gooood my man!!!!!
    I'm glad that your order from PG Saw made it out prior to the effects of our postal strike here in BC, it's really bad now.
    That's the beauty of having all of the parts on hand, you can make changes to their orientation as you see what works best.
    Do you have your electronics box sorted out, along with the power supply(s)?
    Heeeeyyyyy, those dual motor L-brackets look awfully familiar, LOL!!!
    I can vouch for how solid that system is, and if you can also add a rod between the spare holes on the top of the motor gear casings it'll be even sturdier.
    Mine also doubles as the hanger for the feedback pots, so it serves a dual purpose.
    Please keep those pics comin'!!!! :popcorn
  7. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    I haven't had a chance to get the controller box and power supply sorted yet. I do have all the parts on hand. Just trying to finish up the levers and rods to gear box.
    Yea, those brackets are sturdy.:thumbs
  8. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Today I was able to put levers and push rods together. its looking more like a motion rig now!:grin
    Will weld levers to 12 mm rods when everything starts to move so I can still make adjustment if i need too.
    56658552126__9E0D2331-60BF-4545-8635-7726103983D7.JPG 56658556111__C7E5F9B9-AADA-4CBB-B21F-88F7E72AF676.JPG
    Next up Control box. Got this pelican case that will fit JRK's and fits perfectly under the seat.
    • Like Like x 5
  9. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Bwoah, didn’t get much done this weekend as this thing called “family time” got in the way, smh!;)
    Drilled through rod and tapped with m4 screw to prevent it from spinning independently.
    upload_2018-12-16_15-41-7.jpeg upload_2018-12-16_15-40-26.jpeg upload_2018-12-16_15-39-29.jpeg
    Finalized gearbox and levers.
    Will probably be able to do control box and the electronics in the coming few days.
    Hope I can qualify for a DIY license.
  10. Kranky Pantz
    Canada, Eh!
    1,288Coins
    You are killin' it!!!!!
    "Hope I can qualify for a DIY license."
    Are you kidding me?????
    At this rate you are most likely qualifying for a MEDAL!!!!
    :cheers
  11. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Thanks Kranky!
    Getting the electronics ready. Will request license when everything is hooked up.
    Can’t wait for this thing to move! I get in the rush mode mentality and have to stop and tell my self to slow down a bit as I end up messing things up.:(
    So far so good though!
  12. Kranky Pantz
    Canada, Eh!
    1,288Coins
    Live For Speed is perfectly usable with the demo version of SimTools.
    Once I had that functioning properly I requested a DIY license in order to progress and get into the real nitty-gritty of testing.
    My DIY license was granted within 24hrs, or more like 12hrs if I remember correctly.
    I still plan on upgrading to the Pro license sometime in the future, once I'm more comfortable with refining my profiles and wish to move on to the more advanced features such as Game Dash & Remote Profiling.
  13. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Was able to get JRK’s hooked up to power and it didn’t blow up so I’ll take that as a win. Didn’t have a chance to do JRK utility yet as it was getting late. Once I get the fan and access holes done then I’ll hook it up to PC and see what happens.
  14. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Today I was able to finish the electronics. It came out pretty good. Nice and compact.
    upload_2018-12-20_19-32-13.jpeg upload_2018-12-20_19-33-3.jpeg upload_2018-12-20_19-33-54.jpeg
    It’s Alive!!!
    Was also able to do a test. Wow this thing is awesome. To compare, It’s like going from a cheap steering wheel to a direct drive wheel. I only had bass shakers before and this thing is on another level. It’s louder than it is in real life as I was pointing my phone directly at the rig.
    I am experiencing a little problem though. One of the two PSU keeps cutting off and tripping. Sometimes it’s the left and sometimes it’s the right. I don’t have cheap knock off power supplies either. I have meanwell units so I doubt it’s that. Maybe it’s one of the setting in the JRK utility.
    On the end of this video the left PSU tripped.
    If anybody have any idea why the PSU is tripping, please let me know. Thanks!
    153,001Coins
    +11,116 / 56 / -2
    A few suggestions.
    With a lever range anything over 40 degrees up and down is really inefficient in terms of torque utilisation, and yours look like they are well over that.
    How well is the rig balanced,with you in it, as it is a bit hard to judge from the camera angle.
    What is the CTC distance on the levers, because on a compact design torque matters more than lever linear speed.
    Are you using clip on ferrite magnets on usb cables, as that and good cable management will help mitigate interference.
    Can you please post pictures of all of your JRK settings.
  16. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Hey Noorbeast,
    Yes, levers does go over 40 degrees up and down. It’s set to 45 degrees right now. I’ll lower that to 40 degrees.
    It’s well balanced as I sat on it before I installed the motors and levers and was able to keep my self up for a while with out tipping over.
    CTC distance is 50mm
    Ferrite magnets check. Have it on all my usb cables as OSW also produces a lot of EMI.
    Here is my JRK G2 utility settings
    Thanks for your help!
  17. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Was able to fix my issue and now it’s awesome!!!
    Called Pololu support and suggested to add shunt regulator between PSU and JRK G2’s.
    Installed shunts and no more PSU cut offs.
  18. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Hey Noorbeast,
    Now that that problem is resolved. Is it a good idea to have a little angle on the lever rods. I have my set to 10 degrees forward right now. Is it a good idea to leave it that way or should I make it straight when it’s leveled?
    153,001Coins
    +11,116 / 56 / -2
    Torque utilisation is most effective at 90 degrees, so it really is a question of how your rods are set up, whether they are perpendicular or angled. But either way 10 degrees is less of an issue that having a range that is well over 40 degrees up and down,as effective torque utilisation drops of pretty dramatically after about 38 degrees.
  20. Watchumacallit
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    Ok, thanks! I did drop it from 45 degrees to 40 degrees. I also lessened rod angle from 10 degrees to 5 degrees. You are right though as I can’t really tell the difference between 5 and 10 but I did notice a better response from 45 to 40 degrees
