Question Simtools+SMC3 startup position and PWM speed
Discussion in 'SimTools compatible interfaces' started by Lin166, Dec 13, 2018.
  1. Lin166
    Lin166 New Member
    142Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 6DOF
    I just started my model of 3DOF simulator, based on Arduino+L298N drive+ DC motor+Potentiometer. Now the model can work with SMC3 code and Simtools v2.o. The wire connection and communication is good. Great thanks to @RufusDufus and @yobuddy .
    But I had two further questions in Axis Testing:
    1. startup position
    In SMC3 code, the initial value for target and feedback is 512, the mid value of the potentiometer. But when I turn on Axis Testing in Simtools, the motor shaft startup goes much lower. Actually, the position feedback from potentiometer is about 335. Why big gap? Does Simtools reset the initial value?
    SMC3 code
    Actual Startup in Axis Testing
    2. PWM speed
    In SMC3 code, the PWMmax and PWMmin is 200 and 100 separately. And when I test the motor by manual mode in SMC3 Windows Utility, the actual speed is correct. The motor moves fast. But when I run Axis Testing in Simtools, the motor is very slow. The max speed looks like about pwm 100+. Does Simtools reset the PWM value?
    SMC3 code
    At last, my settings in Simtools is below for reference.
    Interface Setting
    Axis Assignment
    Axis Testing
    154,837Coins
    +11,227 / 57 / -2
    Just so you are aware, in your Axis Assignments the actual full movement range is 100 total, and you are trying to allocate 300 total, something it can't physically do.
  3. yobuddy
    51,775Coins
    What keeps the models top platform from twisting clockwise and collapsing?
    I think you need some sort of anti-twist setup for the model.
    Like even a cardboard hinge maybe.
    (drawing terrible but I could not find a pic of a real sim with a hinge setup)
  4. Lin166
    Lin166 New Member
    142Coins
    Hi @yobuddy , thanks for suggestion. Actually, I am also thinking about how to keep the model from twisting ~40 degree clockwise. I will try the hinge setup. Any thoughts about the questions above about the startup position and speed in SimTools Axis Testing?
  5. yobuddy
    51,775Coins
    Nope, SimTools has no way to change these setting in the Arduino.
    I can't speak for the SMC3 settings, as I have not used it for a bit, but SimTools works like this:
    The startup position SimTools sends depends on your output bit settings.
    If you select 8 bit output, with 256 position possible (0 to 255), you can get the center location buy 256 / 2 - 1 = 127
    So for 10 bit 1024 position possible (0 to 1023) you would go 1024 / 2 - 1 = 511.
    SimTools will send a 511 for the center location for 10bit.
    Hope that helps,
  6. BlazinH
    16,704Coins
    Simtools has nothing to do with pot values.
    Simtool doesn't control the PWM value either. When you make changes with smc3 utilities they are saved to the arduinos eeprom including the PWM settings. So the default values at the top of the sketch are overwritten when the eeprom is read if you made changes. Btw, why PWMmin set to 100? That means when your motors start they run at 39% full power for minimum speed. If you need much you've got bigger problems.
  7. Lin166
    Lin166 New Member
    142Coins
    Hi noorbeast, thanks for reminding. Do you mean allocate 300 total such as pitch heave? Based on my understanding, the percentage of the force of the axis should depend on the value range of the potentiometer. Yes, the model physically can't do something. For example, when the motor turns to the lowest position (zero degree), the potentiometer reading isn't the minimum value. But if I adjust the percentage as 70% or 80%, both the highest position and the lowest, which the motor is able to get , will change. The motor avoids the physically impossible part, meanwhile it cannot reach the top (180 degree). It's a little dilemma for me.
    154,837Coins
    +11,227 / 57 / -2
    I mean SimTools presumes an axis total movement is 100%, hence if you allocate more than one axis force it gets a partial allocation of the 100% that is available. So if you have pitch, roll and heave allocated to one axis, and you hit a huge embankment that triggers all 3 simultaneously, then the allocation for each should not really exceed 100% or clipping can result. In practice you can get away with a little over the 100% total, but not the 300% you have allocated.
    See here for tips on creating and refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  9. Lin166
    Lin166 New Member
    142Coins
    Thanks for description, Yobuddy. My understanding is 100% same as yours. The startup position depends on output bit setting. I select 10 bit output, so the position range is 2^10=1024 (0-1023). The center should be 511. But it's weird when I turn on Axis Testing, all motors go lower position with potentiometer reading ~350... Even I set Startup-Output <512> in interface, the result is same...
  10. yobuddy
    51,775Coins
    I think you should set these to 511.
    SMC3 code
    Please open your axis assignments and load the preset for XD Motion. (remember to click Save)
    It should work pretty well for that platform.
    Are you by any chance using any axis limiting?
    Chat soon,
  11. Lin166
    Lin166 New Member
    142Coins
    Got it, thanks, BlazinH. Yes, I have to set PWMmin 100. In the model, the friction force from the pot is too big for the gear motor (6V 30RPM). If the PWMmin is smaller, sometimes the motor is stalled in motion.
  12. yobuddy
    51,775Coins
    Also for a simple test, in Output Testing (in GameEngine), select "(a) Axis Output" in the Output Type drop-down box.
    (This skips all the dof testing and allows for direct output to each axis)
    take care,
  13. BlazinH
    16,704Coins
    Just as I suspected but good thing its just a model. :thumbs If that happens on your full size build however it will be severely under-powered, at least for most racing.
  14. Lin166
    Lin166 New Member
    142Coins
    Got it, thanks. I will try it. Currently I am not using the axis limiting.
  15. Lin166
    Lin166 New Member
    142Coins
    Absolutely, I will pay attention on the full size simulator. It's my next step.;)
  16. Lin166
    Lin166 New Member
    142Coins
    I'm afraid the Output Type drop-down box (Output Testing->Axis Testing) is in locked. There is only "DOF Output" in the box. I cannot see the selection you mentioned. :( My SimTools version is 2.3.1 demo.
  17. yobuddy
    51,775Coins
    You have to turn it on first buddy, then you can select it.
  18. MrDemon
    MrDemon New Member
    - 84Coins
    Hello. How did you solved this problem? I have the same trouble (((
    The SMC and SIMTOOLS "centers" are different.
    When I take the slider in simtools to minus, it works from zero of simtools . When I take the slider to plus, it seems to work from zero SMCUtil. The difference between zero of simtools and zero of SMCUtil is this jerk. :sos
    As I see it - the problem is just in different centers between the simtools and SMC .
    SOLVED You have to change Win Regional Settings to English )))))
  19. marco cristopulos
    marco cristopulos New Member
    139Coins
    What is the layout config to join h bridge l298n to anduino, pls help me
    154,837Coins
    +11,227 / 57 / -2
    An l298n is only rated 2Amp, what do you plan using it with?
