Question 6DOF HeXpod: DIY or COTS
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by FoxONe42, Oct 20, 2018.
Tags:
  1. xxpelle
    xxpelle Discord "TPMax#9574" Gold Contributor
    620Coins
    A small test with own 6DOF model
    driven by Arduino Uno and SimTools
  2. Gadget999
    12,035Coins
    Looking good. What spec are the gearmotors ?
  3. xxpelle
    620Coins
  4. FoxONe42
    FoxONe42 6DOF newbie
    Flight simulator engineer
    Nantes France
    101Coins
    Arduino, 6DOF
    Thanks for the info, that seems promissing indeed. Just to make sure I understand correctely, with such a solution, will there still be a need for external position sensors ?
  5. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    Apparently not. That's the thing!
  6. xxpelle
    620Coins
    This is just a small model with about 40cm. The motors are only RC servos. I only built the model to test the control via SimTools.
    I'm planning a big version with these engines
    "https://www.ebay.de/itm/Schneckenge...var=462497333564&_trksid=p2060353.m2749.l2649 "
    "https://www.ebay.de/itm/Schaltnetzt...var=631661607841&_trksid=p2060353.m2749.l2649 "
    "https://www.ebay.de/itm/Double-BTS7960B-DC-43A-Stepper-Motor-Driver-H-Bridge-PWM-For-Arduino-Smart-Car/200950936475?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649 "
    and the rest of metal
  7. xxpelle
    620Coins
  8. FoxONe42
    Nantes France
    101Coins
    Arduino, 6DOF
    Really awesome if that's the case. I looking forward to having more information regarding this feature.
    Are you planing on making some tests with your Clearpath servo at some point ?
    @xxpelle
    I really like the design of your scale model, very neat.
  9. xxpelle
    620Coins
  10. Jürgen Schon
    Jürgen Schon Member
    57Coins
    Hi Pelle,
    Wie hast du die Maße für die Boden Plattform und die obere Aufnahme errechnet?
    Würde gerne einen solchen Simulator bauen. Ich nutze jedoch folgende Motoren mit einem 8:1 Übersetzungsgetriebe.
    https://www.ebay.de/itm/EU-Free-Shi...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    Danke
    English:
    Hi Pelle,
    How did you calculate the measurements for the ground platform and the upper seat?
    Would like to build such a simulator. However, I use the following engines with an 8: 1 transmission gear.
    Thank you
  11. SilentChill
    20,596Coins
    Hi just a thought from my own experience, I really wouldn't use these they are 8 euros for a reason https://www.ebay.de/itm/Double-BTS7960B-DC-43A-Stepper-Motor-Driver-H-Bridge-PWM-For-Arduino-Smart-Car/200950936475?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
    I would extremely and highly recommend using sabertooths far superior to those. I have tried them and they were garbage for my 6DOF. I would spend the extra $$$$ and buy once not 3 times like I did ;)
    https://www.robotshop.com/uk/sabert...SeZRsF8Ky13WLytvneZt66avQhlA-doxoC4FUQAvD_BwE
  12. Jürgen Schon
    Jürgen Schon Member
    57Coins
    @SilentChill thanks for your tip.
    But my Steppers have their own driver. I can control them with an arduino.
    So i dont need a Sabertooth or something else.
    did you use steppermotors?
  13. SilentChill
    20,596Coins
    You are buying worm gear motors no ? The link was to worm gear motors anyways. If you are using stepper motors you wont need the driver that you linked either ?
    I dont have stepper motors I have SMC3 code running on 3 x Arduinos running 6 12v DC Motors
