value1
Assetto Corsa Plugin 2.0.7.1
SimTools plugin for Assetto Corsa
  1. yobuddy
    51,530Coins
    @optical10,
    Are you tryin to play on a PC or a ps4 buddy?
  2. optical10
    optical10 Member Gold Contributor
    694Coins
    @yobuddy PC but the non-UDP says connected but not blue game running like the UDP says, strange?
  3. yobuddy
    51,530Coins
    Did you patch/activate the non udp one?
  4. optical10
    694Coins
  5. optical10
    694Coins
  6. optical10
    694Coins
    yes I did patch/activate the Non-UDP one but I must of actually patch the UDP one as well my mistake!
    So I went into the Sim tools folder in the users/App Data hidden folder and deleted both the "assetto-corsa" & "assetto-corsa UDP" plug-ins and repackaged with the non-UDP patch only to the non-UDP game manager option but it still says is connected but the game is not running in blue as you can see on the screen grab below?
  7. yobuddy
    51,530Coins
    Please try re-patching the game.
    Let me know how it goes buddy.
  8. optical10
    694Coins
    Okay so I removed the patch, went into the game and did five laps and completed the race, then I re-patched like you suggested but still I get the same screen grab as I showed before, i.e. it shows that I'm connected but there's no blue game running in games manager, only on this game all other games work.
  9. optical10
    694Coins
    @yobuddy Okay everything is fine now, looks like I had to do some more laps to get more game data, thanks for all your help
  10. nclabs
    196Coins
    Asking for a friend, does this plugin output the ABS channel? Thanks.
  11. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Ciao @nclabs
    I think the answer is "no".
    See the plugin specifications here: https://www.xsimulator.net/community/marketplace/assetto-corsa-plugin.179/
    Motion data: This plugin provides pitch, roll, yaw, surge, sway, heave acceleration and traction loss.
    DashApp Data: Speed [km/h], RPM, gear, shift light, fuel [lt], fuel [%], car model and track name. Additional values are feasible, yet not implemented.
  12. nclabs
    196Coins
    I was asking exactly because those "additional values are feasible", maybe value1 could add it in the next release. Cheers.
  13. ilbiga
    Network Engineer
    103Coins
    Ok, sorry. I believed that the question was "generic" and referred to the data currently managed by the plugin. :thumbs
  14. nclabs
    196Coins
    No need to apologize man! :D
    Ciao ciao!
  15. Hame
    Hame New Member
    - 10Coins
    I am a rookie with simtools. Reading a lot here on the forum. Just got it to work with AC.
    I think it is very aggreessive , i am bumping and jumping in my chair.
    Does anyone know how to solve this please?
    Thanks!
    Rob
  16. ilbiga
    Network Engineer
    103Coins
    Ciao @Hame .
    First of all did you load the default profile in SimTools for Assetto Corsa? After this, try to take a round slowely without crashes and than change the settings on the axes.
  17. Hame
    Hame New Member
    - 10Coins
    Thank you for the quick reply.
    I loaded the AC profile, did a lap and safe the new settings in the tuning center.
    On iracing is it far less bumpy and jumping. Got the problem with AC.
    Thanks.
  18. ilbiga
    Network Engineer
    103Coins
    @Hame: have you tried to unpatch and repatch the game after what you described? o_O
    153,812Coins
    +11,150 / 57 / -2
    See here on how to refine a motion profile, initially doing one axis at a time: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  20. The Iron Wolf
    The Iron Wolf Active Member
    Bellevue, WA
    375Coins
    3DOF, SCN6
    Hi, thanks for sharing your profile, I am new to game vibe, and learned that there's 3D mode from your pictures. I am curious, why did you choose to use 38hz-40hz range for Chassis? Thanks!
