2 dof (arduino-ibt2) in costruzione...
Discussion in 'DIY Motion Simulator Projects' started by Stank8, Dec 23, 2018.
  1. Stank8
    Stank8 New Member
    Italia
    - 3Coins
    Ciao a tutti, vi presento il mio simulatore ancora in costruzione, presto diventerà anche dinamico 2DOF con motori Motion Dynamics 24v con elettronica arduino+IBT2, per ora ho realizzato solo la struttura e il prototipo del movimento con motori tergicristallo (solo per provare l'elettronica). Ciao a presto IMG_0125.jpg IMG_0129.JPG IMG_0131.JPG IMG_0139.JPG IMG_0150.JPG
    152,325Coins
    +11,072 / 56 / -2
  3. Stank8
    Stank8 New Member
    Italia
    - 3Coins
  4. Stank8
    Stank8 New Member
    Italia
    - 3Coins
    Hello everyone, I present my simulator still under construction, will soon also become dynamic 2DOF with Motion Dynamics 24v engines with electronic arduino + IBT2, for now I have realized only the structure and the prototype of the movement with wiper motors (just to try electronics) . bye, see you soon
  5. micma80
    micma80 Member
    548Coins
    Hi, can I ask you which engines are you using? (motion dynamics 24V model?). Thank you
    micma
  6. Stank8
    Stank8 New Member
    Italia
    - 3Coins
    Hi micma80, this is the model i want to by. Bye
  7. micma80
    micma80 Member
    548Coins
    Thank you. In Italy or the EU, I do not find dealer/seller of these models. From Australia the shipping cost is high, I would be 90 EUR per engine shipped by ordering 4 engines.
    Do you know if there are valid alternatives in Europe?
    These models are steel metal, or delrin version gear motor?
    Thanks a lot
    Micma
  8. Stank8
    Stank8 New Member
    Italia
    - 3Coins
    hello I'm Italian, in Italy and Europe I'm not available, you can buy them only in Australia and the shipping cost is quite high.
    Alternatively you can find Chinese gearmotors or wiper motors. I want to buy these because then put them left and right in the same position and are very used in DIY sims. the gears should be plastic (delring). Bye
