test simtools+stepmotor
Discussion in 'DIY Motion Simulator Projects' started by Bordiin, Jul 25, 2016.
  1. yobuddy
    51,524Coins
    I think 4 neoprene isolators would do the trick nicely.
    maybe mount then to a piece of plywood to hold them to the floor?
    being rubber they will bend and give a bit as needed I believe.
    (looks great either way!)
  2. joe extraknow
    joe extraknow Member Gold Contributor
    1,550Coins
    I am confused with Simtool on this. The motion is 3dof, so only 3 actuators are needed indeed. Thus, such behave shown is expected. D-box 4-actuator rig somehow seems not show such behave, but I notice that their SW has a module for suspension settings.
    If you add those isolators to fix all 4 legs on the ground as well as angles, such restriction would result in a reduction of resolution and movement, wouldn’t?
  3. yobuddy
    51,524Coins
    The isolators are rubber, once connected to the end of a actuator, you can still bend the actuator around up to say 40deg in all directions.
    It would simply keep it from jumping of the ground I believe.
  4. mm982566
    mm982566 New Member
    US
    56Coins
    3DOF, 4DOF, 6DOF
    Please will you open your Arduino code?
  5. Xiansheng
    Xiansheng New Member
    china
    - 355Coins
    Hello, I like your project very much.Can you share your arduino code and debugging software,Thank you
  6. alejandro2lanz
    alejandro2lanz Lanz
    San bartolome
    118Coins
    2DOF, SCN5
    Hello is a very interesting project, could you share the Arduino code?
    Regards
  7. AndreFilipe
    AndreFilipe Andrefly
    businessperson
    Brasil
    - 55Coins
    3DOF, DC motor, SCN6, SimAxe, Arduino, SimforceGT, Motion platform, 6DOF
    Can someone help me where I can find this code for stepper motors for me to try here in Brazil how is it! Thank you very much and congratulations to everyone!
  8. harrie
    harrie Member
    coevorden
    221Coins
    Arduino, 4DOF
    is there already a arduino sketch for this setup ? arduino mega /uno ? did update my cnc machine to servodrive , got now leftover 4 x nema 34 with drivers and 12 nm ...1605 trapezium ballnut and tread . pom-c ballnut
    153,728Coins
