Mi nuevo proyecto - My new project
Discussion in 'DIY Motion Simulator Projects' started by miguel, Dec 27, 2018.
  1. miguel
    miguel Member
    Student
    Mexico
    343Coins
    Hola a toda la comunidad .
    Pues bien me estoy incursionando en esto de simulación por ahora solo tengo un cockpit simple sin movimiento . Les dejo foto
    DeepL translate:
    Hello to the whole community . Well I'm getting into this simulation for now I only have a simple cockpit without movement . I leave you photo
    152,319Coins
    +11,071 / 56 / -2
    You have come to the right place, there is a really active community here who freely give of their time and expertise.
    You will find plenty of helpful information in the FAQs: http://www.xsimulator.net/community/faq/
    You can go through existing member projects for specific ideas or inspiration: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    Or search for specific types of projects using the Google Custom Search function on the Recent page: https://www.xsimulator.net/community/find-new/posts?recent=1
    Good luck with your project.
  3. miguel
    miguel Member
    Student
    Mexico
    343Coins
    Gracias por la información .
    Intente poner motor de limpiador pero falta fuerza alguna recomendación de motores?
    Es un 2 DOF para unos 100 kg totales
    152,319Coins
    +11,071 / 56 / -2
  5. miguel
    miguel Member
    Student
    Mexico
    343Coins
    Okay sorry.
    Thanks for the info .
    Try to put wiper motor but lack any strength of engine recommendation?
    It's a 2 DOF for about 100 total kg
    152,319Coins
    +11,071 / 56 / -2
  7. miguel
    miguel Member
    Student
    Mexico
    343Coins
    ok thank you I'll check it out for now this is the breakthrough.
    152,319Coins
    +11,071 / 56 / -2
    That is a compact design, so you likely need all the torque you can get, nothing like these, with 60:1 gearboxes: https://www.motiondynamics.com.au/1...ve-geared-motor-200w-21-256-rpm-7.5-45nm.html
    Another observation to think about, levers and rods are most effective in terms of torque utilisation when operating at no more than 40 degrees up and down, with the levers being at 90 degrees to the direction of applied force when the seat is level. Your rig would likely work better, even with the current motors, if the levers pointed forward, parallel to to the ground, with the rods perpendicular when the seat is at rest position.
  9. miguel
    miguel Member
    Student
    Mexico
    343Coins
    152,319Coins
    +11,071 / 56 / -2
    I initially used the MD 200W 25:1 motors on my compact rig, I still have those motors but switched to 60:1 gearboxes because of the better torque for a compact design.
  11. miguel
    miguel Member
    Student
    Mexico
    343Coins
    ok maybe try those and in the future update the box. One doubt needs less torque with the engines further back and rods on the back?
    152,319Coins
    +11,071 / 56 / -2
  13. miguel
    miguel Member
    Student
    Mexico
    343Coins
    thanks, this is another configuration that I have opportunity maybe it is better with the 25: 1 and in the future the boxes 60: 1
    152,319Coins
    +11,071 / 56 / -2
    That would be perfect for the 25:1s.
    The 60:1s are really suit a compact designs that need plenty of torque.
  15. miguel
    miguel Member
    Student
    Mexico
    343Coins
    hello again, I saw your post @noorbeast and very beautiful you simulator congratulations, I saw that in version 1 you had the engines that I ordered 200w 180rpm 25: 1 and you had only two, the question is if it felt somewhat limited? or was going well fart decided you change the boxes
  16. noorbeast
    152,319Coins
    +11,071 / 56 / -2
    I changed the 25:1s to 60:1s for a number of reasons. First was load carry capacity, the 60:1s can handle users of around 140+kg. Second was that 60:1s can't be back driven, so I can use my rig as an office seat when un-powered.
  17. miguel
    miguel Member
    Student
    Mexico
    343Coins
    okay, thank you very much .
    in the future I will update to 60: 1 or more.
    for now the shipment came out very expensive and I will try the 25: 1. waiting for them to arrive I share photos of my wiring work.
  18. miguel
    miguel Member
    Student
    Mexico
    343Coins
    Wiring
  19. MarkusB
    4,215Coins
    Hi @miguel,
    I also used the 1:25 motors and bought them from MotionDynamics with immense shipping costs to Germany. (Should have contacted the vendor MotionControlProducts in the UK instead.)
    Then I changed from shoulder mount to a more compact design, and since I did not want to spend another hundreds of Euros for new gear boxes, I built a 1:5 chain gear by myself. The components were rather cheap. See here for some details. It worked quite well, but in the meantime I switched to second hand wheelchair motors.
    Good luck with your build!
  20. miguel
    miguel Member
    Student
    Mexico
    343Coins
    thank you .
    Of course I will review it, and if it is a big money .
    I will send it however I will be putting as I go with the progress, what time it took to get your motors to apologize?
