Assetto Corsa Competizione Plugin 2.0.0.0
SimTools plugin for Assetto Corsa Competizione
  1. michael münscher
    michael münscher New Member
    Germany Thüringen
    45Coins
    thanks it works great
  2. f1iceman
    - 87Coins
    hi sorry to bother you all, I am having issue with getting the motion for ACC to work I seem to get it shutting the game engine down once I start to load the sim.
    any ideas what I have done wrong.
    installed the patch as per normal but says installed and then patch it and says installed but when I run the game and check the task bar the engine just closes before the first screen comes up, game manager says its working and is blue.
    thank you all in advance
    keith
    152,571Coins
    +11,087 / 56 / -2
  4. f1iceman
    - 87Coins
    I will try to get some posted tomorrow.
    Obviously be from before I launch the game.
    Every other SIM works just project cars2 I've not setup and nolimits2 I've just been messing about getting up.and running again, had a new nvme drive and setup to duel boot see with xplane11/orbx on the other drive, so 're installed my driving rig side and ticking each one off.
    A.c. works, dirt rally works so far.
    Thank you for getting back to me, and happy New year xsimulator.
    152,571Coins
    +11,087 / 56 / -2
    There are some specific in-game settings that are needed for ProjectCars 2: https://www.xsimulator.net/community/faq/projectcars.188/
  6. f1iceman
    - 87Coins
    These are my setting but not sure what your after.
    Game runs then the shuts the main engine down yet says good and blue on game manager no motion or sign of it's working in the sim.
    20190116_210345.jpg 20190116_210437.jpg 20190116_210449.jpg 20190116_210456.jpg 20190116_210518.jpg 20190116_210557.jpg 20190116_210345.jpg 20190116_210437.jpg 20190116_210449.jpg 20190116_210456.jpg 20190116_210518.jpg 20190116_210557.jpg 20190116_210623.jpg
  7. f1iceman
    - 87Coins
    So from now I launch the game and the game engine ahuts down if i press windows key its not there in the task bar anymore.
    Is it some kind of admin I need to use for this SIM.
  8. yobuddy
    51,221Coins
    @f1iceman,
    Are the IP addresses for both GameManger and GameEngine 127.0.0.1?
    In the second pic it looks as if GameManger is connected, but GameEngine is not.
    (GameEngine has a little red square in upper right corner of GUI indicating its not connected)
    Chat soon,
  9. yobuddy
    51,221Coins
  10. f1iceman
    - 87Coins
    Works with other games, would it change for ACC then ??
    I will try get some checks done tomoz.
  11. f1iceman
    - 87Coins
  12. yobuddy
    51,221Coins
    No, it would be either the default 127.0.0.1 for both unless they were edited.
    I think the service got updated with this new conflicting port.
    So it may not have been a problem till now?
    Let me know how it goes!
  13. Jaysonchou111
    Jaysonchou111 New Member
    188Coins
    GREAT plugin,thanks
  14. Damien
    Damien Member
    watchmaker
    Royan
    724Coins
    2DOF, SCN6
    Hi.
    I have the same problem mentioned above, I had version 0.6 today and after having patched the game, I have no movement of the cylinders ...
    I did not have previous versions so I do not know if it comes from the new build ...
    I put D-BOX and also fanaled on enable in the game but nothing happens ...
  15. Damien
    Damien Member
    watchmaker
    Royan
    724Coins
    2DOF, SCN6
    After a lot of trying to find a solution, I think I know where the problem is.
    It seems that there is a problem with the access path because when I run the game then a game manager game remains "CONNETED" but never "GAME RUNNING" appears ...
  16. Nono_006
    Nono_006 New Member
    71Coins
    Thank you,
    I'll try as soon as possible
  17. Pastrana
    Pastrana Member
    Argentina
    165Coins
    For the gamevibe it does not send corresponding data to chassis, the rest of the telemetries if it works perfect. It will be a plugin problem or it will be that you are not sending the chassis telemetries.
  18. Pastrana
    Pastrana Member
    Argentina
    165Coins
    This is video the problem
  19. JayMonkey
    JayMonkey New Member
    52Coins
    Hey Guys,
    I have ACC V1.0.2 installed ... Motion Control is working fine with this plugin but Game Dash (V2.1) is not working for me.
    There is no entry for ACC in Game Dash under Profile Management -> Game Selection, but in Game Manager it shows that the ACC Plugin V2.0.0 is installed and the game patched ?
    No data shown in game dash when ACC is running
    Is there anything special that needs to be done to create a game dash profile for ACC .. i thought it should just appear in the Game Selection list once the plugin is installed ?
    I also have the original Assetto Corsa installed and Game Dash works fine with it .... (using the AC Plugin)
    Any help or advice ....
    Cheers
    Jay
  20. yobuddy
    51,221Coins
    @JayMonkey
    If your using SimTools v2.3.1, then you need GameDash v2.2 buddy.
    Take care!
