Kermit Kong's 6DOF Project
Discussion in 'DIY Motion Simulator Projects' started by kermitkong, Jun 15, 2016.
  1. noorbeast
    152,319Coins
    +11,071 / 56 / -2
    You should check the FAQs first when you have questions or ideas: https://www.xsimulator.net/community/faq/
    The FAQs cover things like controlling rumble style motors with Game Dash: https://www.xsimulator.net/community/faq/rumble-motors-using-game-dash-for-control.272/
    And SimTools settings, tips and tricks: https://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    Also please start your own thread and post your questions there, rather than on other member's threads.
  2. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,239Coins
    Hi guys,
    My 6DOF motion seat build is done since one year about. Everything is still running no issues at all. I play ‘elite dangerous’ with VR and it’s a perfect combination.
    2B19513E-5BF7-4F55-868E-48A4255CE375.jpeg 5268E651-F258-4E4B-96E1-EA5680B7ECE9.jpeg
    • Like Like x 8
    • Winner Winner x 4
  3. Zwodog
    Zwodog New Member
    Austria
    65Coins
    Motion platform
    Hello Kermit
    Congratulation! As I am still working on clearing out some space for "the man cave". I hope I have not missed that info in your thread, that I have studied quite offen.... May I ask for the footprint of your 6 dof base, height of racing seat base and maximum lateral, anterior/posterior and vertical travel during setup and operation for orientation concerning minimal space requirement.
  4. kermitkong
    1,239Coins
    hi @Zwodog
    please have a look to the PDF, which shows the footprint of the motion seat.
    bottom_frame.pdf
    for all the other documents please checkout the project folder:
    https://1drv.ms/f/s!AmCwooBbjonBvUZAY8u_qfKTertc
    the whole motion seat height is about 1.75m (TOP of the mounted seat on the assembled plattform)
    Best,
    Kermit
  5. Zwodog
    Zwodog New Member
    Austria
    65Coins
    Motion platform
    Thank you very much! I completely missed that information in that folder!!! As i have focused only on the linear actuator build. May I ask another question, I hope I can make myself clear...
    Can you give me an rough estimate on how much elevation the seat has and how much movement to the side. I mean how much additional space to the base platforms do you need to the left and right for maximum lateral travel?
    Thanks for your help and support and time and the great information already provided.
  6. Zwodog
    Zwodog New Member
    Austria
    65Coins
    Motion platform
  7. Runconcept
    Runconcept Runconcept
    128Coins
    Bonjour, t'es un pro pour monter les simulateur.
    J'habite à l'île de la Réunion est je vais monter mon 1er simulateur rallye et avion chasse en 6dof.
    Jai besoin d'un coup de main, concernant les mesures de la structure les moteurs utilisés et un schéma électrique car je vais utiliser arduino mega.
    Mervi
  8. kermitkong
    1,239Coins
    Hi @Runconcept
    Sorry cannot understand French
    If you want to have a look to my projects in detail pls check the project Pages:
    Project linear actuator build:
    https://1drv.ms/f/s!AmCwooBbjonByhqoqaRkCaglHnqk
    Project Servo actuator build:
    Best,
    Kermit
    152,319Coins
    +11,071 / 56 / -2
    It is also best to create your own build thread and post your questions there: https://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    Do spend a little time doing some research, you will find useful information to get you started in the FAQs: https://www.xsimulator.net/community/faq/
  10. jeep213
    jeep213 New Member
    中国
    232Coins
    The “Regeneration Energy Buffer” and “24V Power System” are very encouraging. I copied the circuit diagram and learned it, and I will do the same. thank you very much.
  11. kermitkong
    1,239Coins
    Build your own 6DOF motion seat now !
    found a Perfect Motor plus gear for only 24,95 euro each.
    please have a look at www.pollin.de
    search for:
    DC-Getriebemotor, VE 31-F-B-2, 64 U/min, 24V
  12. dedraro
    dedraro Active Member
    105Coins
    Why are they so cheap? the motor is included or it is only the gearbox?
    I'm trying to buy them unfortunately they only ship to Germany, do you think there is a way to buy them from Italy? thanks a lot
  13. alexdraco
    alexdraco Member
    278Coins
    Ciao,
    great project!
  14. anatachaikiet
    anatachaikiet New Member
    184Coins
    great very good [​IMG] [​IMG] [​IMG]
    and you can give me about drawing hall effect pot.. thank you
  15. kermitkong
    1,239Coins
    don’t know exact what you mean.
    But all Mechanical and electrical drawings of the complete project are free and available on request.
    best,
    Kermit
  16. thewaggy
    thewaggy I am one of the two funny three.
    Austria
    - 9Coins
    2DOF, Arduino, 6DOF
    Hi, I am new here, which Ardurino Code did you use ?
  17. ikesimuladores
    ikesimuladores New Member
    Brasil
    80Coins
    Kermit_Kongs-Romulator2_Actuator .PDF file is not opening
  18. kermitkong
    1,239Coins
  19. ikesimuladores
    Brasil
    80Coins
  20. Nicki9knuckles
    Nicki9knuckles Active Member
    Web Developer
    740Coins
    3DOF, DC motor, Motion platform
    Hey @kermitkong can you tell me what it is you have to search for to find these rods? I am new to this, and I know I need tire rod ends, but I am not sure what I am looking for when search for the rods to connect them.
    Thank you!
