Question One of your Interfaces Requires GameEngine to be Restarted
Discussion in 'SimTools DIY Version' started by IRaceSim, Jan 4, 2019.
  1. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    Hello everyone, I spent all day trying to understand the problem, I also searched the forum, there is no apparent solution. I turn the screenshots around so you can see the procedure that leads to the error. I have two SCN5 actuators which work perfectly with another program. I tried to run simtools with the Virtual Sim App, the software works. The actuators work with another software and are centered and powered. Help Me
      72.3 KB
      795
  2. yobuddy
    51,559Coins
    Try one at a time buddy.
    Do you know if your SCN actuators are both connected to a single serial converter?
    Or do they both have their own adapter?
    Chat soon,
  3. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    QUOTE = "yobuddy, post: 169629, member: 72"] Prova uno alla volta amico.
    Sai se i tuoi attuatori SCN sono entrambi collegati a un singolo convertitore seriale?
    O hanno entrambi il loro adattatore?
    Chat presto,
    yobuddy [/ QUOTE]
    Hello, both actuators are connected to cards like this one
    the two usb cables are connected to a USB hub ,. The hub connected to the PC has been deprived of the power supply wires, red and black, as it created me a power return that damaged my motherboard.
    I thought that this configuration created problems, so I connected the usb cables directly to the pc, but the simtools created the same problem.
    I also tried with one rocker at a time, but nothing.
    The thing I'm sure of, that is a problem between program and actuators, because with another software the actuators work perfectly.
    I'm demoralized.
  4. yobuddy
    51,559Coins
  5. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
  6. yobuddy
    51,559Coins
  7. Christian Bürgin
    Christian Bürgin New Member
    69Coins
    3DOF, AC motor, SCN6, Motion platform
    Wich Software? Thanks
    153,986Coins
    +11,162 / 57 / -2
  9. Nico57050
    Nico57050 New Member
    - 54Coins
    3DOF, SCN6
    Hi, I read the FAQs but I don't know how to change an actuator's ID.
    I'm just a beginner with Simtools
    Thanks.
  10. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    Good evening everyone,
    I always have the same problem. Now with the previous experience I have put ID = 0 to both actuators but it doesn't work the same. I am going crazy
  11. yobuddy
    51,559Coins
    Test one actuator at a time and see what happens buddy. (basically, remove interface 2)
    (With SimTools 3, you can test one interface at a time if you are using it?)
    Let me know how it goes.
  12. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    Hi, my friend
    I use the version 2.5.3, which gives me this error.
    I used version 3, but i am not getting any signs of life from my actuators.
    With the actuator software I set both ID = 0, but the error always comes out.
    I also tried with only one actuator, same thing.
    Several times I have had this problem, i am confident in solving it.
  13. yobuddy
    51,559Coins
    Check the other interfaces (3 thru 6) and make sure you don't have any settings for them.
  14. yobuddy
    51,559Coins
    when you start simtools do your scn actuators center?
  15. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    There isn't other interfaces
  16. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    When i start Xsimulator my scn actuators don't center.
  17. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    I try to change ID and change COM, i try every possibility but the error message return.
    I try again with Sim Tools 3 - But there is not errore message, the actuator don't move.
    With the SNC5 software the actuator is perfect.
  18. yobuddy
    51,559Coins
    Rae you trying to run the SNC5 software and simtools at the same time?
    I have a scn simulator here and its working great.
    I would set up one actuator at a time, and restart simtools and see if you can get one to move.
    Chat soon!
  19. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    I also have a SCN sim. i just changed pc. I tried to use one actuator at a time but same problem. I'll try to figure out what's wrong. I don't use the scn5 software together with XSim, I only use it to set up and test the actuators. We keep up to date.
  20. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    This morning i tried to connect the actuators one at a time, setting Xsim and closing it each time, but i couldn't.
    I tried to change COM, and i tried to change ID, but i couldn,t.
    this morning i tried to connect the actuators one at a time, setting Xsim and closing it each time, but i couldn't.
    Anyone can tell me what else can try?
    I've always had this problem but always solved, but now i can't understand.
