Working in SMC, Axis tests and dof test but not LFS
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Trigen, Jan 19, 2019.
  1. Trigen
    Trigen Active Member
    2,891Coins
    Hi
    Unsure where to post this so im trying here. I cant for the life of me get any reaction from LFS
    Its working fine in SMC and in Axis
    It seems to be stuck in Sway when i test forces regardless of what i set as force on Axis1a and save. Its late though and im quite tired
    Ive patched the game.
    I can feel it sets to center when i start the game.
    Ive tried all launched as administrator
    Tried default settings.
    Tried lots of other axis settings with no change.
    Any ideas?
    153,884Coins
    +11,154 / 57 / -2
    You need to run a few laps in first person mode before patching, as that generates some required files.
    So if you did not run LFS first then un-patch, close SimTools, run some laps in LFS, reopen SimTools and re-patch.
  3. Trigen
    2,891Coins
    Thanks will try that in the morning!
