Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.1.3.0 pointer update
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,065Coins
    Wagnard submitted a new resource:
    Elite Dangerous Horizons Plugin (XML edition) - Elite Dangerous Horizons
  2. Wagnard
    Wagnardsoft
    5,065Coins
    Some of you may be interested to know how to find the pointers as me or Silentchill may not be available or we can simply lost interest of doing it.
    So here is a little how-to that will help you out.
    If you can manage what the guy is doing in his video than you almost got it already.
  3. Grigory
    Grigory Active Member Gold Contributor
    Moscow
    220Coins
    3DOF, 6DOF
    Hi @Wagnard, I'm getting this message when trying to patch the game using your plugin. Do you know what I may be doing wrongly?
    I downloaded the plugin, unpatched the game using GameManager in admin mode, closed GameManager, dragged the plugin zip to PluginUpdater window and then tried patching using GameManager in admin mode again.
    Thanks in advance!
  4. Wagnard
    Wagnardsoft
    5,065Coins
    That's weird, try again I would say? Be sure to run as administrator for game manager. Sometime it doenst work first time.
    Is there other message before this one?
  5. Grigory
    Moscow
    220Coins
    3DOF, 6DOF
    No, that’s the only message I’m getting
    I’ve tried installing SilentChill’s plugin — that one worked. Then I unpatched the game, installed your plugin and tried patching, but the same message appears.
    I also tried rebooting without any luck.
  6. Grigory
    Moscow
    220Coins
    3DOF, 6DOF
    Do I need to do anything with xml file? I do not see it in the zip file of the plugin.
  7. Wagnard
    Wagnardsoft
    5,065Coins
    Weird I'll check later.
    Be sure you have the latest simtools
  8. Grigory
    Moscow
    220Coins
    3DOF, 6DOF
    Thanks!
  9. Wagnard
    Wagnardsoft
    5,065Coins
    Can I know ,where on your HDD, simtool is installed?
    • Dislike Dislike x 1
  10. Grigory
    Moscow
    220Coins
    3DOF, 6DOF
    D:\program files\simtools
  11. Wagnard
    Wagnardsoft
    5,065Coins
    Ok. That's the reason. Currently it is hardcoded in the plugin to be in drive c.
    Either you wait for me to update (will take a little while I have work today) or simply reinstall simtool to to D:\program files\simtools
  12. Grigory
    Moscow
    220Coins
    3DOF, 6DOF
    Thank you very much for identifying the cause so quickly!
  13. Wagnard
    Wagnardsoft
    5,065Coins
    Just realized I did a typo, I of course meaned to reinstall in C:\program files\simtools
    Or just wait for me to update
  14. Grigory
    Moscow
    220Coins
    3DOF, 6DOF
    Thank you very much. It indeed worked after I moved the SimTools installation to C:
  15. Wagnard
    Wagnardsoft
    5,065Coins
    Thanks for the confirmation. I will still fix this as soon as I have a little free time.
    I will also probably remove the need for the admin rights too.
  16. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    810Coins
    • Like Like x 6
  17. Wagnard
    Wagnardsoft
    5,065Coins
    A small steam update this morning seems to have broken the pointers :(
    So i'm on it.
  18. Wagnard
    Wagnardsoft
    5,065Coins
    Wagnard updated Elite Dangerous Horizons Plugin (XML edition) with a new update entry:
    Read the rest of this update entry...
  19. splendiddd
    CCTV security
    Netherlands
    810Coins
  20. George Dobransky
    Hungary
    - 43Coins
    Hi There,
    This is my system. With this new plugin with full SRV movements......3-4 hrs of play with Elite EVERY SINGLE DAY!!!! THX Wagnard!
    Cheers,
    George
    • Like Like x 5
