AC VR motion compensation with Oculus is it possible?
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by TheCalVRsimer, Jan 22, 2019.
  1. TheCalVRsimer
    TheCalVRsimer New Member
    346Coins
    3DOF, Motion platform
    Very new at this, so forgive me for my ignorance.
    I just got a 3DOF platform and everything works fine. What I am trying to setup at the moment is the motion compensation in Assetto Corsa with Oculus using OpenVR Input Emulator v1.3.
    So far I can setup OpenVR without any issues, it seems, but once I open AC, it is very obvious the motion compensation doesn't work.
    Everything is setup correctly:
    - Two Oculus cameras (OK)
    - Oculus Touch Controller attached to my seat by my head (OK)
    - OpenVR Input Emulator v1.3 setup:
    - Device identified
    - Device Mode: Motion Compensation
    - Motion Compensation Settings: Set Zero
    - Press Apply = OK​
    Do I have to keep OpenVR open after setup is done?
    Is it because AC does not use Steam VR to work with Oculus?
    I saw in AC there is an OpenVR render mode, should I use that instead of Oculus?
    Thanks for any help concerning this issue,
    TheCalVRsimer
  2. SilentChill
    20,601Coins
    Yes you need to edit a line in the ini I found it randomly whilst trying to get Oculus Runtime v1.7 working , wouldn't need motion cancellation if I could get it working . Hopefully below screen grab makes sense :)
  3. SilentChill
    20,601Coins
  4. SilentChill
    20,601Coins
    Just realised you are talking about the old AC ?? if so you need to select openvr in the display option in game :D
  5. TheCalVRsimer
    346Coins
    I'll try that, great if it's that simple.
    Thanks for your help : )
  6. TheCalVRsimer
    346Coins
    Hi again,
    As of today I am still unable to get the motion cancellation to work with AC or RF2 with openVR Input Emulator v1.3.
    I have been following the DOF Reality's instructions, looking online for other tutorials, nothing is really helping.
    Could you describe the exact steps required to make it work with both sim?
    Hope you can help,
    Thank you very much for your time spend on this issue. Sorry for not being better at this.
  7. TheCalVRsimer
    346Coins
    Finally got it to work : )
  8. occhiso
    occhiso New Member
    Software Developer
    Australia
    55Coins
    I'm a n00b and just came across this thread.
    Congrats on getting it to work with the rift!
    I only just realised motion cancellation was something I need to worry about, any resources/threads you could provide as a starting point for setting this up?
    Does it depend on the game or can it be setup for anything?
    (I'm not quite ready for it, I don't have a rig... yet, but I'm keen to learn more)
    153,728Coins
    The current solution is SteamVR based and motion cancellation is a bit hit and miss with the Rift, which has no native solution: https://www.xsimulator.net/community/threads/vr-motion-cancellation-time-to-test.10241/
  10. TheCalVRsimer
    346Coins
    The motion compensation is actually completely independent of any games and can be setup for anything that will work with SteamVR. It works every time for me now without fail.
    I'll detail the steps tomorrow as it is a little late for me right now. It is actually quite simple, I was only missing one little detail to make it work.
    To be continued...
  11. 9xclubchamp
    9xclubchamp New Member
    Woodbury
    311Coins
    Hi CalVRsimer, I'm new here and saw your post, did you ever post your step-by-step solution somewhere?
    153,728Coins
    Unfortunately CalVRsimer has not been active since Mar 24, 2019, so I doubt you will get a response.
    As I mentioned this is the current state of play:
    But toward the end of that thread is notification about members seeking to make a more robust generic motion cancellation fork: https://www.xsimulator.net/communit...lation-time-to-test.10241/page-48#post-193130
