Project Cars 2, gamevibe - not working?
Discussion in 'SimTools Plugins' started by Mik, Jan 22, 2019.
  1. Mik
    Mik New Member
    172Coins
    Hey.
    Searched around, found an old post that was of no use; I still have an issue - i can get 3dof motion working great in pcars 2, but no matter what i do gamevibe is not working/activating.
    I have updated the plugin, enabled gamevibe ( like i did for iracing/asseto corsa) - but.. nothing!
    Any ideas?
    153,986Coins
    +11,162 / 57 / -2
    It is annoying but I have to start SimTools, go to Game Manager and turn it off on the top left button to disconnect SimTools, then start PC2, the re-click the Game Manager button to On to reconnect SimTools, otherwise Game Vibe does not initiate, which is something @yobuddy may be able to investigate.
  3. Mik
    Mik New Member
    172Coins
    Ah ok - thank you. I will try this. Do you use shared memory and udp set to pcars 2, or any other stuff i should know?
    153,986Coins
    +11,162 / 57 / -2
    I am away traveling for the week but am pretty sure my shared memory is set to PC2.
  5. yobuddy
    51,558Coins
    rgr, I'll check it out...
  6. Mik
    Mik New Member
    172Coins
    please do - i built my entire rig around this, and im so sad i cant use my 6 buttkickers at the moment :((((..
    Crossing my fingers you will get this done soon - hopefully - and THANK you for your massive efforts in this area.
  7. Mik
    Mik New Member
    172Coins
    I cannot get this working btw. I tried starting game manager, game engine - then gamevibe. Then turning off game manager. Then launching pcars 2 from steam - then as it starts up, enabling - doesnt work. Tried waiting until it was at menu before starting - doesnt work. Tried waiting until i was in game, before enable - doesnt work.
    I have tried udp and shared memory in all possibilities - doesnt work.
    Which version of gamevibe are you using and what plugin? Id love to make this work now, if possible at all!
    153,986Coins
    +11,162 / 57 / -2
    I am on SimTools v2.3.1 and use the original Pcars2 plugin: https://www.xsimulator.net/community/marketplace/pcars2-plugin.147/
  9. Mik
    Mik New Member
    172Coins
    My problem is solved. It turns out, .. ..... ...... i didnt calibrate it with the tuning setup.
    Im a moron. I tried EVERYTHING else.. but forgot that. Maybe the manual should be rewritten to have all it has, but also have a small list of things you need to do in order - like that crucial step. its easy to overlook int he middle of it all!
  10. early_m
    early_m Active Member
    Chelmsford
    839Coins
    I'm also having this issue - can you detail how you solved it?
  11. Kenshiro27
    Kenshiro27 Active Member
    252Coins
    2DOF, 3DOF, Arduino
    Hello Early_m,
    I have the same problem as you on PC2 while on PC1 no worries, we gave you the answer or did you find a solution to this problem ?
