Configure axis profiles and problems to install other users of the forum.
Discussion in 'New users start here - FAQ' started by sulfail, Jan 24, 2019.
  1. sulfail
    sulfail Member
    Mason
    vigo(pontevedra) SPAIN
    205Coins
    Hello everyone, I have movement but I do not understand much how the effects are configured, I also have problems to install the configuration files of other users, normally I only find files with the .config extension and those that have my simtools are .pre and I do not he accepts them. It is difficult to understand the effects for each axis, I configure it using trial and error but I do not understand them and I read the guides and I do not understand, example in assetto competizione I work sway, arise and heave but if I put rool or pitch I do not know Notice those effects, how many effects can I put? simtools assetto.png simtoos.png
  2. sulfail
    sulfail Member
    Mason
    205Coins
    ah I use the same effects in the axis assingaments a and the axis b assingnament, is it ok? axiso.png
  3. sulfail
    sulfail Member
    Mason
    205Coins
    if I add rooll that effect I do not notice it when climbing curbs, I do not notice anything of that effect, the others if I notice them. rooll.png
    152,319Coins
    +11,070 / 56 / -2
  5. sulfail
    sulfail Member
    Mason
    205Coins
    In the end, I left it like this in (a) confirmations and I have copied in (b) confirmations the same thing because I felt that the effect surge out of balance and, therefore, I noticed it well, I have increased the sway effect more and I like more.I notice more of the curbs, so I have removed the roll effect because it does not do anything. If I leave only 1 assignment with the effects, the increase is more noticeable on one side than on the other, so I use the two controls on the axes, so when the braking effect is very even, I like it better.
    Only with the surge effect does the mismatch go through, so I use the 2 assignatives a and b.
