Question Simtuning G seat Sway no negative beyond center on a flap while one raise. Or axis neg clamp?
Discussion in 'SimTools DIY Version' started by Trigen, Feb 2, 2019.
  1. Trigen
    Trigen Active Member
    2,891Coins
    Hello
    I got my G seat built and set so i dont have much negative axis to go on. Looking into for example dirt rally if i tune one axis that i do not wish to go negative i can do -50 or whichever number i need. Problem seems to be that this affects it when it needs to go down normally from top too, from what i can see anyhow. Is there a clever way for it not to go below center pot and still retain its speed? Ive had to mount one motor the opposite way from the other too, can this have an effect? I dont think so on the sway.
    The best would be if i could actually limit the negative throw for all axes not to go beyond center pot from the axis me
  2. yobuddy
    51,559Coins
    If your using a Arduino, simply edit the sketch you are using buddy to ignore the negative side of things.
    Take care,
  3. Trigen
    2,891Coins
    Cool, thanks! Not a clue how SMC3 so more questions and research :) Any chance you got a hint?
    153,986Coins
    +11,162 / 57 / -2
  5. BlazinH
    16,691Coins
    After the code where the sketch inputs data from simtools test when the required axis drops below 511 and when it does make it stay at 511 until it goes above again.
  6. Trigen
    2,891Coins
    Thanks for taking the time. But im not quite sure where that would be. Got a line number and a copy of some of the code?
    Cant i use this ( ive edited) clip code for it?
    Code:
    int InputClipMax1 = 600;    // The input position beyond which the target input is clipped
    int InputClipMax2 = 600;    // The input position beyond which the target input is clipped
    int InputClipMax3 = 600;    // The input position beyond which the target input is clipped
    int InputClipMin1 = 512;      // The input position beyond which the target input is clipped
    int InputClipMin2 = 512;      // The input position beyond which the target input is clipped
    int InputClipMin3 = 512;      // The input position beyond which the target input is clipped
  7. Trigen
    2,891Coins
    Thanks guys looking into the faq and such now
  8. BlazinH
    16,691Coins
    Yes it appears the code that tests is already in there and you just need to change the values to what you want to use.
  9. Trigen
    2,891Coins
    Does not look like it cares about any input i make to the clipping or max limit settings. Ive been testing it in the gameengine and LFS.
    If i set fks the int Target1 = 512; to 600 in the sketch it will move to 600 on upload so i know it will use that atleast.
    Test limits example, i generally set it at 480 min 550 max for testing
    Code:
    int InputClipMax1 = 518;    // The input position beyond which the target input is clipped
    int InputClipMax2 = 518;    // The input position beyond which the target input is clipped
    int InputClipMax3 = 518;    // The input position beyond which the target input is clipped
    I can see that it first writes the limits to EEPROM then it reads it and set InputClipMax1 = 1023-InputClipMin1;
    Why does it take the Clipmax and set it to 1023 then subtract ClipMin? Wouldnt this remove any setting i set on top and replace it with 1023 - lets say 200 = 823. Now Clipmax is 823. I dont see it doing this with ClipMin anywhere but i dont have a full overview of the sketch. Main issue of course is that (Simtools) it does not seem to care what i set in either Clipmax or Min. im not a great programmer som im not sure how all this works.
    Code:
        EEPROM.write(5,DeadZone1);
        EEPROM.write(6,CutoffLimitMin2);
        EEPROM.write(7,InputClipMin2);
    Code:
        CutoffLimitMin1 = EEPROM.read(1);
        InputClipMin1 = EEPROM.read(2);
        CutoffLimitMax1 = 1023-CutoffLimitMin1;
    Thank you
  10. BlazinH
    16,691Coins
    Okay what you were trying to do won't work for several reasons so I modified the sketch so it clips targets when they drop below 512. :popcorn
  11. Trigen
    2,891Coins
    Cheers. Have a beer on me!
    153,986Coins
    +11,162 / 57 / -2
  13. SeatTime
    Your clip code was not were I expected it to be..., but did you also apply a 'map' function to get back the full movement of the servo/motor?
  14. BlazinH
    16,691Coins
    No nothing I read indicated that he needed that.
    Also this was intended to be a one-off and not a fix for everyone.
  15. Trigen
    2,891Coins
    I didnt say anything about it as i didnt know about it but a full range map from clip value would be the best of course. With that in mind i have a questions. If the game gives me a value of 450 will the axis go to 512 and stop there or will it ignore it completely? Same with values above but thats not much of an issue as i can set the axis limits in simtools. It would however save some slight time for new people.
    For the main testing part ive had to do some slight modifications to your code to make it work.
    This is being tested with the SMC packet serial for sabertooth
    If you use #define REVERSE_MOTOR1 setting the limits will not work as intended. It will be the opposite of what it should be and if you set the values in reverse it will just sit there and shake.
    Setting the value to 512 cen lead to the motor shaking due to dead zone being to small.
    In the code file above there is InputClipMax1 = 1023-InputClipMin1; It needs to set to a value say 650 or you will get 1% range on the axis and it is required for this to work. Just so there is no confusion here. You can set it to 1023 and use axis limit in simtools or if you know the value you can set that.
    Code starts at line 526
    Code:
    //    Read all configurable parameters from the EEPROM.
    void ReadEEProm()
        int evalue = EEPROM.read(0);
        if(evalue != 114) //EEProm was not set before, set default values
            WriteEEProm();
            return;
        InputClipMin1 = 500;
        InputClipMax1 = 650;
        DeadZone1=EEPROM.read(5);
        CutoffLimitMin2 = EEPROM.read(6);
        InputClipMin2 = 500;
        CutoffLimitMax2 = 1023-CutoffLimitMin2;
        InputClipMax2 = 650;
  16. BlazinH
    16,691Coins
    An axis will go to the value set in inputclipmin and hold that value until it goes above it again.
    And since your range now appears to be around 150 (out of the 512 you currently have available) you don't require more motor range so no need for mapping. If anything it sounds like you could stand to use a lesser rotation pot (like 180 or 90 degree) to try to increase the resolution. But if your happy with the motion your getting probably no need for that either.
    Btw, when I edited the sketch I made it so that inputclipmax would still be changed when using SMC3 utilities. But hard coding a value like you did is fine too.
  17. Trigen
    2,891Coins
    Ive been working around this for a while now and it can make the flaps flap back and forth quite a bit when it hits the clip limit. Seems it would be best to give it a proper range.
    Im assuming i need to do something like this
    If (range > 0) range = 128; // or another number depending on how range is set up
    Im not quite sure where i would need to change it. Be specific
  18. BlazinH
    16,691Coins
    If anything it appears you need a lesser rotation pot to increase the resolution.
  19. Trigen
    2,891Coins
    I'm running a 2:1 gearing so it's not an issue. Those numbers are no longer valid. Just need to set the range and not use clipping as any slack in the system leads to flapping when hitting the clipping limits (especially on startup) unless you set the dz very large.
  20. BlazinH
    16,691Coins
    It could be you have to much slack then. In any case you can't set a range when using absolute position sensors you can only remap it. However remapping doesn't change the actual resolution so I don't know what you would gain other than using a larger percentage of the graph when using smc3 utilities. To me it appears your problem is you are overshooting the target since the clip limit just freezes the target at that point. Are your tests always done loaded? Unloaded it would probably act as you state when using settings to make it move properly when loaded.
