Arduino Leonardo SIM Wheel
Discussion in 'DIY peripherals' started by Sieben, Nov 27, 2018.
  1. Sieben
    Sieben Active Member
    2,241Coins
    Hi there)
    Stand alone thread on this build.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    And some build details. Please note this all is just freestyle build without any tough "how to" make it right. It's pretty solid. And in test build though, for now. But works fine.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    And with quick release for a wheel.
    EMC SOFTWARE: - Credited to: EBOLZMAGY.
    https://www.youtube.com/redirect?ev...bqvdywVJx2uescXi4YgN1H_9-k0qUPQ&v=DFDxhd_Gqb4
    Many thank to Bs Simulator.
    Video - cycle test with half of saturation ratio.
  2. Sieben
    2,241Coins
    Have got an idea to move backwards the wheel base itself. This will alow to place the monitor way much closer then conventionally. For that the following is made:
  3. Sieben
    2,241Coins
    Figured out that, if the pulley be placed on the steering column shaft, just beyond the wheel itself, the FFB DIY wheel build, becomes a lot easier thing to be made. The connection with encoder then can go like this.
    [​IMG] [​IMG]
    For now, as it have got to be checked with separate motor base, and be connected with column by means of cardan shaft, some welding works required, to make the know how coupler, fot it.
  4. Sieben
    2,241Coins
    Forse Linearity test, with wheel check, for 'dat build.
  5. Sieben
    2,241Coins
    Figured out the joint without welding. Huh. Left is to the base shaft, and right to cardan. Should make minor outer size reduction of the nut. Outer is 13mm, should be 12mm.
    • Optimistic Optimistic x 1
  6. Sieben
    2,241Coins
    The base itself is kinda ready.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  7. Sieben
    2,241Coins
  8. Sieben
    2,241Coins
    Drill chunk with key is a connector to the steering column shaft.
    But put a base with direct connection to the wheel.
    Put a base on the rubber buffers. No noise)
  9. Sieben
    2,241Coins
    Just to show the ffb rotation rate)
  10. Sieben
    2,241Coins
    Quick release, made simple)
  11. SilentChill
    20,595Coins
    Great stuff , proper DIY :)
  12. Sieben
    2,241Coins
    Thank you very much :)
  13. FargusFaustmeister
    FargusFaustmeister Member
    Engineering Technologist
    69Coins
    Hey, great job on this build. I'm really impressed with your creative solutions. Can I ask you for some details of how the Arduino is communicating with the PC? That is, how is your input/force feedback getting communicated to the computer?
  14. Sieben
    2,241Coins
    Thanks. Well you just make it a HID Devise by dropping hex and that's it for the ordinary user to make it a USB controller with FFB. Connect and plug everything.
    If you interested in a way much deeper concern on it, I don't bother to sort out such details)
  15. Sieben
    2,241Coins
    Have a question. Who can prompt good and simple powerfull MOSFET H-bridge schematic to solder instead of that BTS drivers?
  16. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    i m only using single BTS with over 500 watt power draw and it still alive...the key is control heat appling some termal paste and cooling fan, or you can give it bigger heatsink...
    all i know about high current hbridge only BTS7960 and double vnh2sp30 but thats limited to 16V...
  17. Sieben
    2,241Coins
    ahoenksiluman hello! Yes that should be a reason to it. May be should just try with it really:) So even decided to solder one. :soso_O
  18. Sieben
    2,241Coins
    So the charts in numbers. One rev to 360deg from 0 revs, and time for it. Responce time from the moment the signal are made.
    Some DIYs and not only for comparison.
    Motor770, (100% gain, basicaly 50% gain are used)
    (362.84deg-0.13deg) ( i.m. how many degree close to 360deg, were taken for calculations, and time to reach it consumed.)
    362.71deg for 184ms
    1000ms/184ms = 5.4rev/sec = 324 rev/min minimum.
    8ms to respond from start
    My1025, without wheel, with 12V, 12,5A (150W instead of 300W the motor requires) 1:4gear
    (368.53deg-8.76deg)
    359.77deg for 208ms
    1000ms/208ms=4.8rev/sec = 288rev/min minimum.
    12ms to respond from start
    BSSim My1016, 1:4gear (50% GAIN Mmos)
    (366.59deg-1.79deg)
    364.76deg for 236ms
    1000ms/236ms=4.2rev/sec = 252rev/min minimum.
    6ms to respond from start
    POWER steering motor, Conventional steering wheel, 18.8V
    (362,32-0,26)
    362deg for 236ms
    1000ms/236ms = 4.2rev/sec = 252rev/min
    4ms to respond from start
    CGWheel (Caravangoes), Lightweight wheel, 1:3 gear.
    360.94deg for 246ms
    1000ms for 246ms=4.06rev/sec = 243.6 rev/min minimum.
    And.
    OSW Direct Drive, Sparco
    (361.47-0.39)
    361deg for 304ms =3.28rev/sec=198rev/min
    2_ms to respond from start
    G27
    Just a chart)
    10ms respond from start.
    The scooter motors for ffb wheels, are quite a "that’ll do". [​IMG]
    IR ffb gain was 12% enough. Without IR LUT add on.
    Once again the my1025 rotaion rate. Ordinary heavy wheel.
    Also the BSSim vids.
    https://youtu.be/yiHT_YgN8Aw
    Only, are there a need to use 24V12.5A for 300W motor, (if now 150W-12V,12.5A, are used with 300W motor) if the Mmos (whatever), BSSim gain is set to 50% with full power supply? Guess that'll be all the same. Or better use full power, as the motor requires, and then just set the gain in software?
  19. Sieben
    2,241Coins
    Slow motion with wheelcheck satX50% With 100% will be twice faster then on video.
    With 50satx/ it means 50% of power in wheel check. And with 12V12.5A instead of 24V/13.6A nominal to that motor.
  20. Sieben
    2,241Coins
    The welding joint of the link coupler from shaft to encoder, was broken. The drill makes a deal)
    [​IMG] [​IMG]
