Lotus 49 cockpit rig
Discussion in 'DIY Motion Simulator Projects' started by skydivepaul, Feb 13, 2019.
  1. dododge
    dododge Active Member Gold Contributor
    854Coins
    Oh, definitely no argument about realism/accuracy. My goal was to maximize the sensations I could get from just transducers, even if they were exaggerated like a theme ride. That was actually the second revision where I redesigned the base and spring layout to purposely make it even more unstable, plus you can see that there's flex in the structure which I could have braced into submission but didn't.
    Adding the weight of a driver dampened most of the crazy oscillations from the start of the video (the first version would even start walking across the carpet if you hit the right frequency :)), but there was still a lot of tilt once you started shifting your weight around to fight the steering wheel and Geko chair (also turned to max), and in a VR headset you could certainly feel that stuff happening.
    I had plans for making it an even wilder ride by independently spring-mounting the seat and pedals and then attaching the transducers more directly, but before I got there my desire for a better heave effect pushed me to a commercial 4DOF and the shaky rig went back to a pile of parts.
  2. dododge
    854Coins
    My setup was an example of the very high side of things, probably $1500+ just for the transducer setup (yeah, yeah, I know that's enough to DIY an actual motion rig). Buttkicker LFEs are $200-$300 each, the high-power amps they require are $250-$300 each (per two transducers), then there's the software, sound card, and parts to build cables since the amps I used only allowed for Speakon connectors.
    In the past year I've seen even more extreme setups with something like 6-8 LFEs or Concerts (the 2Ω equivalent).
    There's also 1000W transducers available from Earthquake that are capable of a longer throw or something like that, but I don't recall if I've seen any driving rigs using them.
  3. skydivepaul
    skydivepaul Member
    282Coins
    Motion platform
    Had a few hours on the rig today and got the cockpit more or less sorted. Nearly ready for some paint, perspex screen and decals.
    I guess the rig weighs around 40kg but i will get it on the scales once its complete and start looking for some kit to get it moving.
    I am thinking a 2 dof system on a platform so i can put the rig on and off for transporting
    153,734Coins
    I am looking forward to seeing your rig with the finishing touches, which can only enhance the craftsmanship that has gone into it.
  5. skydivepaul
    skydivepaul Member
    282Coins
    Motion platform
    Not had chance to do any work on the sim for over 6 weeks, work, holidays etc.
    Got a few hours in it tonight, got the pedals in, sub woofer and speakers plus the roll bar. Nearly there now !!
  6. skydivepaul
    skydivepaul Member
    282Coins
    Motion platform
    Cockpit screen made and fitted. Gauges wired up, ready for painting and livery
    20190428_162209.jpg 20190428_121316.jpg 20190428_162354.jpg 20190428_121303.jpg 20190428_162610.jpg
  7. skydivepaul
    skydivepaul Member
    282Coins
    Motion platform
    Nearly there now, decided against paint as the ali looks so good. Got the stickers on , just a few numbers to fit.
    I have a tv stand so will be setting the xbox up as a test this week with the surround sound and amp. Using forza 7 with the open wheel classic cars.
    Once happy will look at the motion and a pc set up
    • Like Like x 5
  8. skydivepaul
    skydivepaul Member
    282Coins
    Motion platform
    Finally got it up and running. Using forza 7 for starters, the sim works great and the surround sound system with subwoofer shakes the car over the bumps.
    Going to enjoy it for a little while then think about adding the motion.
    20190514_084835.jpg 20190514_084847.jpg 20190514_100126.jpg 20190513_201828.jpg 20190514_084825.jpg
    • Like Like x 5
  9. dualclick76
    dualclick76 Active Member
    italia
    19Coins
    painstaking work, very precise, very complimentate
  10. skydivepaul
    skydivepaul Member
    282Coins
    Motion platform
    After much deliberation i am considering
    selling my lotus 49 cockpit rig to make way for my new full motion project.
    Any ideas on what price point to set?
    I have seen a similar cockpit available for around £3k but these are grp moulded, no wheel or pedals and no dashboard. I have also seen a full blown replica with exhausts etc and fully loaded for £50k
    Just testing the water so any feedback appreciated
    153,734Coins
    Hard to say, but likely you would need to test the waters further afield than here, which is predominately DIY, if you are looking for top dollar.
  12. skydivepaul
    skydivepaul Member
    282Coins
    Motion platform
    Yes tricky where to put the price point on it. No rush as i really would want to keep it anyway. Just need some space for my other project(s)
  13. ferslash
    ferslash Active Member
    4,798Coins
    First chat all, grate build how thik is hoy aluminium?
  14. skydivepaul
    skydivepaul Member
    282Coins
    Motion platform
    The aluminium panels are 1mm thickness
  15. ferslash
    4,798Coins
    until now i realized i got a typo on my last post. i am sorry, again, grate sim...
    and... just for cience :D:D:D how did you attached the aluminium to the wood... are those rivets?
    best regards
  16. skydivepaul
    skydivepaul Member
    282Coins
    Motion platform
    Hi, the ali is attached with lots of small pan head scews. I wanted to use rivets but they didn't work well into the wood frame.. cheers paul
  17. Surge
    Surge New Member Gold Contributor
    Tech Entrepreneur
    Toronto
    356Coins
    3DOF, SCN5, SCN6, Arduino
    Did you sell it?
    My Lotus 18 sim is finally here...
  18. Kenshiro27
    Kenshiro27 Active Member
    252Coins
    2DOF, 3DOF, Arduino
    In short, magnificent. If the movement is equal to the exthetic, here is an exceptional simulator.
