Mi nuevo proyecto - My new project
Discussion in 'DIY Motion Simulator Projects' started by miguel, Dec 27, 2018.
  1. miguel
    miguel Member
    Student
    Mexico
    343Coins
    I dont have idea
  2. miguel
    miguel Member
    Student
    Mexico
    343Coins
    I managed to get SMC3 to recognize Arduino, this is achieved by loading the file SMCv1.7 softsatart.ino into Arduino
  3. miguel
    miguel Member
    Student
    Mexico
    343Coins
    but now I do not know where I'm standing, I do not know if I skip steps, I do not know whether to load code from Arduino 2 DOF. I do not know if removing potentiometers and testing the engines with SMC3. I'm looking for outings but I do not know if I do the right thing
  4. miguel
    miguel Member
    Student
    Mexico
    343Coins
    I finally managed to make the SMC3 work correctly with Arduino, even moving motors in its different tests.
  5. miguel
    miguel Member
    Student
    Mexico
    343Coins
    now I need to make it work with simtools 2 any suggestions?
  6. miguel
    miguel Member
    Student
    Mexico
    343Coins
    This
    151,528Coins
    +11,042 / 56 / -2
    Glad you got SMC3 sorted OK.
    You can't run the SMC3 utility and SimTools at the same time, it will cause a port conflict.
    Setup for Simtools 2 is very straight forward, you need to correct your Interface Output settings in the interface Settings, copy and paste this in: [A<Axis1a>][B<Axis2a>]
    Next you will need to do a basic Default profile in Axis Assignments.
    The Dir boxes being checked orange or not determine which way each axis moves, and this is what SimTools expects, the movement can be checked in Output Testing.
    Once the rig responds as expected you can create and refine a motion profile, initially doing one axis at a time, then tweaking from there: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  8. miguel
    miguel Member
    Student
    Mexico
    343Coins
    @noorbeast I thank you very much for being on the lookout and especially the patience in my post I hope soon it will be ready as it seems to be walking better
  9. miguel
    miguel Member
    Student
    Mexico
    343Coins
    Oh my god, now I do not know what to do. I think I'm worse than before.
    151,528Coins
    +11,042 / 56 / -2
    Ouch...how did the broken gear happen?
  11. miguel
    miguel Member
    Student
    Mexico
    343Coins
    @noorbeast ,sorry you have the 60: 1 boxes? or 50: 1? How do they work? to ask for those for the gear problem that I had
  12. miguel
    miguel Member
    Student
    Mexico
    343Coins
    the part that bears the kneecap was harmed and made more strength, believing and throne
  13. noorbeast
    151,528Coins
    +11,042 / 56 / -2
    I use 60:1s from motion dynamics, which run metal gears. I had a problem of increased free play with one of the original 60:1s, but have never had an issue with its replacement or the other original 60:1 even after years of use.
  14. miguel
    miguel Member
    Student
    Mexico
    343Coins
    Thank you . Will you choose at this time 50: 1 or 60: 1 already with your experience and tests?
    151,528Coins
    +11,042 / 56 / -2
    Part of my reason for choosing the 60:1s is their greater torque, which is important for a compact design, and that they can't be back driven when un-powered.
    Brand new 50:1s can't be back driven, but after some use they loosed up a bit and then can be back driven.
  16. miguel
    miguel Member
    Student
    Mexico
    343Coins
    do not say more 60: 1 hoping not to have setbacks or anything weird
  17. Pedro Andres Pineda
    Pedro Andres Pineda Member
    System engineer
    Colombia
    46Coins
    Hi @noorbeast, I was reading this post and I’m thinking that I have the same problem, could you please validate if your suggestions apply to my design? Do you suggest move my rod to generate the perpendicular(line red)? 0C58AB60-3E87-47B0-ABA7-EB95816F6750.jpeg
  18. Pedro Andres Pineda
    System engineer
    Colombia
    46Coins
    Oh , today I broken one gear box of my simulator too. Definitely I need a better gear box. I’m working with smc3 too, if you have some question maybe I’ll be able to help you.
  19. miguel
    miguel Member
    Student
    Mexico
    343Coins
    hello Pedro I thank you very much, for now I will stop it because I need an engine, or is it possible to program it with 1 engine and since the other one arrives, just place it?
    Pedro where are you from ?
    151,528Coins
    +11,042 / 56 / -2
    That lkooks to be a knee mount design, it does not take as much torque to drive as a compact design, as the design leverage length is bigger, but a knee mount design does need more torque than a shoulder mount design, which has greater inherent design leverage.
    Have a play with SimCalc to get an idea of design choices Vs physics: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
