The Varjo VR-1: $5,995 + required $995 service license (mandatory only for the first year)
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by noorbeast, Feb 19, 2019.
  1. noorbeast
    153,818Coins
    +11,150 / 57 / -2
    The VR-1 combines sports high visual fidelity of any headset and has a proprietary eye-tracking solution with sub-degree accuracy. It's a modular system that is intended to evolve as software and hardware improves: https://www.forbes.com/sites/jessed...est-end-vr-headset-in-the-world/#7268152a5b91
    • Has a replaceable face plate that can support mixed reality
    • Has built in active cooling system to help with comfort
    • Compatible with SteamVR V1 & V2 and ART Tracking
    • 10 meter usb -c, cable tether
    • link box with 1 usb-c, 1 usb-a, 2 DisplayPort connectors
    • 87 degree FOV
    • weight 605g
    • auto IPD through eye tracker
    • combines 1920x1080 microOLED with 1440x1600 AMOLED using a mirror and eye tracker to keep high resolution in center of focus
    • uses dual lenses to minimize reflections, chromatic aberrations, and god rays
    • similar headstrap to Vive Pro
    Side-by-side comparison of Varjo VR-1 (right) and HTC Vive Pro (left)
  2. BlazinH
    16,689Coins
    Looks good but so does the Odyssey +. The +'s fov is 110 and costs a hell of a lot less too. Interesting info though.
  3. SeatTime
    Not impressed :rolleyes:. IMO, with the lenses setup to give 87 degree FOV, the new pimax would look just as, or possibly clearer then this headset - well maybe not....:), but for most people pretty darn good for the money. PIMAX 5K+ at 2 x 2560 / 87 degrees = 58 pixels per degree (VR-1 stated at better then 60 PPD) - so not bad.. the 8k X (if it ever happens) will be even better.
  4. SilentChill
    20,601Coins
    Rip off !!! That is all :D
  5. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    Thanks for info nb
    Regardless of cost it’s good to see higher spec’d headsets being released
    Price of tech decreases as higher end features become mainstream
