first project full frame 2 dof
Discussion in 'DIY Motion Simulator Projects' started by Joeri, Feb 18, 2019.
  1. hannibal
    hannibal Active Member
    4,492Coins
    i feel like i will see more of your posts @Joeri !
    i just started also!
  2. Joeri
    Joeri Member
    car body repair shop
    The Netherlands
    106Coins
  3. hannibal
    4,492Coins
    i just read about the SC3.. looks like you have to put it into MODE2 if you are going to wire like this diagram...
  4. Joeri
    Joeri Member
    The Netherlands
    106Coins
    Got it I am now playing with the SMC3Utils
  5. hannibal
    4,492Coins
    does your electronic components get hot?
  6. Joeri
    Joeri Member
    The Netherlands
    106Coins
    which one ?
    i am still working on SMC3 setup utility
    153,722Coins
    Correct for that controller.
  8. Joeri
    Joeri Member
    The Netherlands
    106Coins
    It is working. Sort of.
  9. Joeri
    Joeri Member
    The Netherlands
    106Coins
    hi guys no real update.
    i am waiting for the test wiper motor. hope i get it tomorrow.
    ordered the aluminum for the bottom frame today.
    now looking for a universal joint.
    does anyone know where i can buy a nice universal joint ?
  10. hannibal
    4,492Coins
    same no new updates, i am just looking at building out the power and driver components.. im still debating on motor driven or go all out and build the actuators...
  11. Joeri
    Joeri Member
    The Netherlands
    106Coins
    B05A7AAE-1CBD-4D3D-B4FB-BFBADA9497E2.png EC91ECBC-D2D7-4168-81A7-B64BEF2CD0D4.png 998F08A5-1A26-48B9-9B84-AAB92839D1AF.png
    I found it on alieexpress. could I use this? instead of windshield wiper motors.
  12. Joeri
    Joeri Member
    The Netherlands
    106Coins
    First smal victory :)
  13. Joeri
    Joeri Member
    The Netherlands
    106Coins
    One more test with simtools and lfs.
    I am so happy this is working now.
    Next step looking for good motors.
  14. Joeri
    Joeri Member
    The Netherlands
    106Coins
    first step with the wiring.
  15. Joeri
    Joeri Member
    The Netherlands
    106Coins
  16. noorbeast
    153,722Coins
  17. Joeri
    Joeri Member
    The Netherlands
    106Coins
    Hi Guys.
    I am working on simcalc.
    is this calculation correct?
    1151.920000 mm/s ??
  18. Joeri
    Joeri Member
    The Netherlands
    106Coins
    Nobody can tell me if this is ok ??
    153,722Coins
    The CTC is too large and the Torque of the motor very low to drive most designs.
  20. Joeri
    Joeri Member
    The Netherlands
    106Coins
    Ok thanks.
    what is a good straight line speed ?
