Question How do I connect arduino to racewheel
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Jakob Carron, Feb 20, 2019.
  1. Jakob Carron
    Jakob Carron Member
    34Coins
    Hi I'm making a diy simulator for playstation 4 using the joystick plugin to control the motors based on the wheel. I'm not sure how I would connect the parts to the wheel. I don't have the arduino or wheel yet, but I'm getting the HORI Racing Wheel and Arduino Uno Rev 3
    150,037Coins
    +10,993 / 54 / -2
    The Joystick plugin allows an existing peripheral to be used for input, it does not need an arduino.
  3. Jakob Carron
    Jakob Carron Member
    34Coins
    Thank you for letting me know that, but how do I connect my wheel to sim tools for it?
    150,037Coins
    +10,993 / 54 / -2
    See the plugin page: https://www.xsimulator.net/community/marketplace/joystick-plugin.127/
    How to use:
    Run GameManager in Admin mode.
    Select the "game" Joypad.
    Patch by selecting the installation directory of SimTools.
    The patch installs a program "SimTools_Joystick.exe" and "SimTools_Joystick_Recorder.exe". These programs do nothing than trigger SimTools to read the Joystick values.
    Run GameEngine & GameEngine.
    Run SimTools_Joystick.exe or – if you watn to record the data – run SimTools_Joystick_Recorder.exe.
    Play with your joystick and observe the values in TuningCenter.
    You can also run a simulation/game in parallel. However certain games (like Codemasters and LFS) must be unpatched first.
  5. Jakob Carron
    Jakob Carron Member
    34Coins
    Thank you, If I have any other questions I will let you know
