  1. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Hi DIY'er,
    I wrote a small Excel programm to get an idea how to set the Kp, Ki and Kd values in SCM3Utils.
    You can just play around with the values and see how the actual curve is following the target curve.
    Not sure if someone else already did that (I don`t read the whole thread), but I find it useful, so I upload it here.
    cheers,
    Arazok
  2. Pedro Andres Pineda
    Pedro Andres Pineda Member
    System engineer
    Colombia
    46Coins
  3. Pedro Andres Pineda
    System engineer
    Colombia
    46Coins
    Currently, we can work with motomonster or with the two H-Bridge, I know the main difference between those is that H-Bridges supports a greater amperage. But Does someone know additional differences( durability, overheat, performance with simtools, etc)
    If my amperage for each motor is less 10 Amp, What would be your recommendation?
  4. Fernando Godinho
    Fernando Godinho Member
    Entusiasta de simulação
    Brasil - São Paulo - Guarulhos
    70Coins
    2DOF, 3DOF, Arduino, Motion platform
    good work I did everything you explained and everything worked everything, now I just need to be able to put the plugins in the folder I do not know where and how to make that folder put I already downloaded the plugins and now I'm having difficulty to continue any help is Welcome, thanks for the support. I'm from Brazil. My ingres is a google translator. Sorry for the input
  5. Pedro Andres Pineda
    System engineer
    Colombia
    46Coins
    When you said plugins, do you mean simtools plugins?
  6. yobuddy
    51,100Coins
    152,319Coins
    +11,070 / 56 / -2
    You need a licensed version of SimTools, see @yobuddy's response on the other thread: https://www.xsimulator.net/communit...me-from-game-manager.11380/page-2#post-173450
  8. Fernando Godinho
    70Coins
  9. Joeri
    Joeri Member
    car body repair shop
    The Netherlands
    106Coins
    played a bit with smc3 today. with the test motors 12v. I only had to use max limits 145. if I set it to 255. then it goes outside the values and goes off. is that OK ?
  10. titomaky
    titomaky Member Gold Contributor
    181Coins
    Motion platform
    Yes, that is correct
  11. Joeri
    Joeri Member
    The Netherlands
    106Coins
    I'm starting to understand. I now have clip input again at 255. And max limits at 150. Now the motor does not switch off when it reaches the clip input line.
  12. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Hi, I have a question wrt to SMC3Utils and SMC3 code which I don`t understand:
    In the code the current and target value of the motor position are sent (back) when issuing the rd (read) command.
    Then this code is executed (example for Motor 1):
    SendTwoValues('A',Feedback1/4,Target1/4,ComPort);
    Why is the Feedback1 and Target1 parameter divided by 4 ???
    Ok, the value can be 0-1023 (10 bit) and on ComPort 8 data bits (1 byte) are transfered. Is that the reason ?
    But then you will get "wrong" values (between 0 - 255 instead of 0 - 1023) on the receiver side (e.g. PC / SimUtils).
    Maybe in SimUtils this is corrected when receiving the value (multiplied by 4) and shown in the graphical output,
    but I am really interested in the purpose behind this.
    Hope that @RufusDufus is reading this :)
    cheers,
    Dirk
  13. BlazinH
    16,667Coins
    It's not important to have these sent back at full resolution to utilities. Utilities is also based on 8 bit values.
  14. hooshang
    hooshang Active Member
    275Coins
    hello guys
    @RufusDufus ,@BlazinH
    could it possible modify SMC3 code that atleast one or two axes cover full 360 degrees.
    thank you
  15. Arazok
    Arazok Member
    Computer scientist
    783Coins
    This is not up to SMC3 code, but rather your potentiometers.
    SMC3 code just calculates with 10 bit values, no matter if those values are spread onto 180 degree or 360 degree....
  16. hooshang
    275Coins
    sure,but iam not talking about single 360 degree turn...i mean continues 360 degrees like in flight sim.
  17. yobuddy
    51,100Coins
    Don't see why not.
    You would have to trap when the rollovers happen and correct the output direction and speed.
  18. motiondynamics
    motiondynamics Member Gold Contributor
    1,215Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, Motion platform, 6DOF
    Hello everyone, this is my first place.
    I have a question for you, dear friends: I would like to use Arduino "standalone" (rebuild a new PCB with Atmega328P) and make it work with FT232RL Converter.
    It's possible?
  19. yobuddy
    51,100Coins
    I don't see why not buddy.
  20. Pastrana
    Pastrana Member
    Argentina
    165Coins
    People I have a couple of years ago running the simo 2dof and I'm having problems that transmits me a bit of movement one engine to the other, I think it's the MM problem, since I have to touch in step I wanted to add a third motor to simulate the skid , in my country everything is expensive, I have before 2 ibt-2 and also 2 MM, I wanted to add two ibt and for the third motor an MM, could this be added to the code of the arduino?
