Question Servo motor. Good or not ?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Joeri, Feb 28, 2019.
  1. Joeri
    Joeri Member
    car body repair shop
    The Netherlands
    106Coins
    2384E730-DC70-4096-B9BA-F152ABA84029.png 137082A9-9578-486F-991F-5C3628A900C4.png 6DBE1734-24DD-42C4-859E-16CC5E601624.png
    I found it on alieexpress. could I use this? instead of windshield wiper motors.
  2. MarkusB
    4,215Coins
    Several forum members are using similar servos, maybe with other kgcm values, like @Spit40 (see here) or @T R Para (see here).
    They may be able to answer your question.
    My personal feeling is that these servos are good suited for moving g-seat paddles, but not for moving an entire seat, because the permanent load would be too high for them.
  3. Joeri
    Joeri Member
    The Netherlands
    106Coins
    Thank you for your answer.
    will read through these topics.
    tonight i want to take a look with simcalc.
  4. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    Markus is correct. They will not work for your main seat moving power. The gears are much too weak and once you add some 50 - 100 mm levers the torque will disappear.
    My first build was with wheel chair motors which are ok for your first build .
    They do have some backlash but are very strong.
    I have a friend in the Netherlands. I will ask him where he got his motors.
  5. Joeri
    Joeri Member
    The Netherlands
    106Coins
    thanks for your comment. I will continue to search for other motors. if you can ask what kind of motors and where your Dutch friend got them from. I would appreciate that ;)
  6. douweeric
    douweeric Repareric Gold Contributor
    Service Engineer
    Nederland
    - 40Coins
    3DOF, AC motor, Arduino, Motion platform, 4DOF
    Hi Joeri,
    u have to use other ones. Contact me so i can let you know
