4 DOF (PITCH-ROLL-TRACTION LOSS-SURGE)
Discussion in 'DIY Motion Simulator Projects' started by Enrico, Mar 11, 2018.
  1. noorbeast
    152,319Coins
    +11,070 / 56 / -2
    Perhaps @yobuddy can think of something to explain the repetative interference data spikes.
  2. yobuddy
    51,100Coins
  3. Enrico
    Enrico Member
    417Coins
    4DOF
    Hi everybody,
    after more then one year finally I started with the add of TL and surge.
    I decided for Ard and sabertooth 2x32 and 2 gearmotors 24 V 60:1. I bought the stuff here on the Marketspace form WP_20190401_20_59_31_Pro.jpg WP_20190401_20_59_52_Pro.jpg WP_20190401_21_01_42_Pro.jpg WP_20190401_21_03_43_Pro.jpg My.stAr
  4. Enrico
    Enrico Member
    417Coins
    4DOF
    Then, in stead of the levers I decided to use the timing belt, and bought some other stuff here, from a store near home .....
  5. Enrico
    Enrico Member
    417Coins
    4DOF
    ... and also have prepare some parts by myself.
    WP_20190412_18_44_03_Pro.jpg WP_20190415_21_09_05_Pro.jpg WP_20190415_21_08_19_Pro.jpg
  6. Enrico
    Enrico Member
    417Coins
    4DOF
    ... in the afternoon played with Ard and Saber.
    Everything seem to be ok :grin
    Manual movements with SMC3 are ok and manual movements with simtool too. Of course these are first movements but I'm happy for that.
    For test I used the PSU of my old pc (12 V ) and it works if I change slowly the direction but if the changement is fast it shut down . But this is normal. The motor is 24 V 250W so....
    I'm ordering a PSU 24 V 1000 W. I think wil be ok for these motors
  7. Enrico
    Enrico Member
    417Coins
    4DOF
    ... Forgot one thing. In SMC3 the buttons motors on/off work only when them wants :think
    If I click on it (this is for all 3) they don't switch or better, switch only sometimes but normally don't.
  8. Enrico
    Enrico Member
    417Coins
    4DOF
    Hi everybody this couple of day I made some work.
    At first disassembling ...
  9. Enrico
    Enrico Member
    417Coins
    4DOF
    .....then
    WP_20190426_10_59_38_Pro.jpg WP_20190426_17_19_21_Pro.jpg WP_20190427_15_54_41_Pro.jpg WP_20190427_20_47_01_Pro.jpg
    TL almost ready.
    A couple of thing to finish off and start to think about sourge :thumbs
  10. Enrico
    Enrico Member
    417Coins
    4DOF
  11. Enrico
    Enrico Member
    417Coins
    4DOF
    Hi everybody, after a lot of time I'm almost ready for the first test with Arduino one and sabertooth but here some pictures of the work done
    WP_20190525_15_37_11_Pro.jpg WP_20190525_15_38_02_Pro.jpg WP_20190525_15_39_09_Pro.jpg WP_20190525_15_36_53_Pro.jpg
  12. Enrico
    Enrico Member
    417Coins
    4DOF
    ...also change the system to use the pots from this
  13. Enrico
    Enrico Member
    417Coins
    4DOF
    ...to this...
    WP_20190530_21_01_19_Pro.jpg WP_20190603_20_43_31_Pro.jpg WP_20190603_20_43_56_Pro.jpg WP_20190603_21_20_00_Pro.jpg WP_20190620_20_26_48_Pro.jpg WP_20190620_20_27_07_Pro.jpg
  14. Enrico
    Enrico Member
    417Coins
    4DOF
    hi, can anybody tell me why the motor buttons of SMC3 doesn't work?
    I can start with the motors but then I can't stop them becaus the buttons stay always ON:think:think:think
  15. Enrico
    Enrico Member
    417Coins
    4DOF
    Hi guys, I finally finished some changes to my system but I'm facing a new problem and I hope someone can help me to solve it! :thinko_O
    Anyway, everytime I start Game Engine it works until I go on output testing tab and when I click on Turn on, it crash after few seconds. I've restart both PC and program like 5 or more times and then it started working correctly but everytime I shut down the PC I have to do the same.
    Looks like something is randomly killing the process but don't know what it is... I already checked if the windows' antivirus was blocking the program or if it could be some conflicts with other processes but nothing...
    Is this happened to anyone yet? Any ideas?:sos:sos
  16. noorbeast
    152,319Coins
    +11,070 / 56 / -2
    Is there an actual error message and if so please open it and copy the full details here.
  17. Enrico
    Enrico Member
    417Coins
    4DOF
    Hi guys, about the problem I have had, firstable sorry for the poor info I gave you.
    I try to explain better.
    Before to modify the rig adding surge and traction lost, this was how it worked:
    Switch on the power to the motors
    Open Game engine
    Motors were centered to zero
    Start the game (Project Cars 2)
    Having fun J
    After the modify :
    Open Game engine
    Motors are centered to zero
    Start the game
    After fews seconds (random) Game engine shut down
    It means the game engine window disappear from the monitor without any warning or message.
    Maybe can useful for someone what I “discovered”
    Normally (with the “old” rig) when Game engine is closed the motors lose the zero position.
    The motors I mean, are the two for pitch and roll that move the seat on the universal joint.
    In this case (with the “new” rig) when Game engine is closed both motors sometimes hold the zero, sometimes only one of them hold the zero but the other one no and this was really strange :think.
    Then I thoug about some hardware problem
    The difference betwen old and new rig :
    Two new motors
    Sabertooth card (for new motrs installed)
    One USB hub to connect PC with Arduino and 2 JRK cards I use for old motors for pitch and roll.
    I eliminated the hub and connected usb cables directly to the PC.
    Tested many times opening and closing Game manager and the game without problems.
    I don’t know if can be possible a connection with the problem but at the moment this seems to be the solution.
    In these days I will test again and if somthing wrong will happen I will upgrade this thread
    Anyway thanks for the support ...and sorry for my english
  18. noorbeast
    152,319Coins
    +11,070 / 56 / -2
    Does Output Testing work as expected?
  19. Enrico
    Enrico Member
    417Coins
    4DOF
    Yes output testing is ok.
    I played PC2 yesterday night a little bit and is fine
    Later I will send some screenshot of the setting
  20. Enrico
    Enrico Member
    417Coins
    4DOF
    .... mybe I will post also a short video "in action" even if I still have to adjust better the axes, but before to do that I would like to upgrade Simtool from 2.3.1 to version 2.4:thumbs
