vthinsel
Project Cars 2 UDP (uses new UDP format) - Manual plugin start 1.1
Project Cars 2 UDP for consoles
  1. noorbeast
    153,830Coins
    +11,151 / 57 / -2
    The Default profile is used to check movement in Output Testing and can also be like a generic template for new profiles, as you can automatically load the Default profile values into a new profile using the Load Default button in Axis Assignments.
    So you are not capturing a Max/Min for Default, but rather have Default values that are a good starting point for creating a new profile on your rig. Hence why I suggested when you have created a sensible Default nothing wild should happen unless a game plugin has 0 for all settings in the Tuning Center.
  2. Pedro Andres Pineda
    Pedro Andres Pineda Member
    System engineer
    Colombia
    46Coins
    Today I was testing the game with Ps4. I have movements, I have captured the max min. But I feel that the movements aren’t associated with the real time in the game.
    I’ve configured f1 2017 and works fine. But I made the same procedure with PC2 but doesn’t work fine.
    Any suggestion?
    153,830Coins
    +11,151 / 57 / -2
    You don't capture Max/Min for the Default profile the way you do for game profiles, think of the Default more as a Template for new game profiles.
    153,830Coins
    +11,151 / 57 / -2
    Can you please post pictures of all of your settings, including for the Tuning Center.
  5. Pedro Andres Pineda
    System engineer
    Colombia
    46Coins
    After all, I had a problem with the lag because I didn't see that my Ps4 was connected with Wifi instead of wired LAN. After connecting the PS4 and my laptop with the wired LAN, all works fine.
  6. Pedro Andres Pineda
    System engineer
    Colombia
    46Coins
    Is possible have 2 Ps4 with Project cars 2 and 2 Pcs with Game manager working with Project Cars 2 with the same Router?
    If PC2 sends the data as broadcast, then I need to generate two different subnets to play with the scenario above?
  7. yobuddy
    51,533Coins
    I believe you can use the windows firewall to block the packets from the PS4 you don't want data from on each PC?
    been awhile but this has come up before i think.
  8. mirel lazar
    mirel lazar New Member
    - 203Coins
    2DOF, 3DOF, SCN6, Arduino, Motion platform
    thanks very much for the plugin.
    I do have a weird case of reversed pitch/heave while running it but funny enough, if I reverse those in axis setup then there is no pitch/heave feeling anymore.
    I captured my own min/max values unbalanced to see if it makes a difference.
    any hints are appreciated.
    here are my settings:
    E38D0594-4DF2-4566-8C56-EBB355AD0224.png D30DD6CD-A3D1-4A2C-AE2E-508F5A1A4BBA.png 4C31C31E-F172-4F6F-BC02-A4531195266E.png
    153,830Coins
    +11,151 / 57 / -2
    With an Axis Assignment total of 260% you are going to get clipping and some weird behavior: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    Try the tuning tips here, in particular stick with sensible allocations, initially do each axis individually, then turn them all on and tweak from there: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  10. mirel lazar
    - 203Coins
    thanks for the tips. I will do it step by step.
    this is the default I use and it seems to work well otherwise.
    in this particular case I feel the pitch/heave well, except that they are reversed (upon acceleration the platform dips, upon braking it lifts).
    cheers
  11. mirel lazar
    - 203Coins
    it turns out it was not the pitch/heave that was causing the problem, but surge.
    anyway, all 3 had to be inverted.
    and yes, testing them one by one was the way to do it, so thanks.
