Wheelchair motors
Discussion in 'Motor actuators and drivers' started by cnupa4ka, Mar 2, 2019.
  1. cnupa4ka
    cnupa4ka Member
    385Coins
    Hello guys. What are you thinking about those motors? You can find very cheap motors.
    Thanks!
    152,319Coins
    +11,070 / 56 / -2
    They would likely work OK for traditional and compact 2DOF rigs.
  3. cnupa4ka
    cnupa4ka Member
    385Coins
  4. cnupa4ka
    cnupa4ka Member
    385Coins
    So guys can u help me with the choice. I am planning to build 2dof sim.
    I have 2 offers for wheel chair motors and wiper motors from Nissan Vanette.
    Thank you in advance!
  5. MarkusB
    4,215Coins
    I am using exactly the wheelchair motors shown in the first photo for my 2DOF simulator, and they work just great. I can fully recommend them.
  6. cnupa4ka
    cnupa4ka Member
    385Coins
    Thanks my friend!
  7. Gadget999
    12,035Coins
    I use wheelchair motors and gearboxes
    They work great
  8. cnupa4ka
    cnupa4ka Member
    385Coins
    what ratio they are? Do u have a video of it?
  9. Gadget999
    12,035Coins
    They are 60:1 iirc
  10. cnupa4ka
    cnupa4ka Member
    385Coins
    yes I saw your project :) Did u have any problems with?
  11. Gadget999
    12,035Coins
    The motors work pretty good, you can make the sim faster/slower by adjusting the lever lengths
  12. cnupa4ka
    cnupa4ka Member
    385Coins
    Is it the same effect on the playing racing games with sim based with wheelchair motors and others DC motors more expensive? How u think? because u can buy wheelchair motors for. 100+ pounds. The other is double priced for example.
  13. cnupa4ka
    cnupa4ka Member
    385Coins
    So guys I have ordered already the motors for 50.00 pounds p&p!
    I hope they will does the job! How do u think?
    24 VDC
    RPM 210
    Gear ratio 25:1
    20 A
  14. MarkusB
    4,215Coins
    The motors look good and are for sure strong enough. The rear part with the little lever is the brake. I removed these brakes from my motors. Did not need them, and in this way they become a bit shorter.
  15. cnupa4ka
    cnupa4ka Member
    385Coins
    Thanks Markus. Can you give me advice for the electronics?
    How do u think for the parts bellow?
    Arduino Uno R3
    BTS7960 (looks cheap staff . Should I trust it? :) )
  16. MarkusB
    4,215Coins
    I am using an Arduino Uno and a Sabertooth 2x32. Not so cheap, but very reliable and easy to setup with the SMC3 sketch & utility that you find in this forum,
  17. cnupa4ka
    cnupa4ka Member
    385Coins
    What about for the power supply?
  18. MarkusB
    4,215Coins
    I am using two 12V power supplies (IBM 1300W System x3950 - 24R2715) and connected them in series for getting 24V. Before I ground-isolated one of them.
  19. cnupa4ka
    cnupa4ka Member
    385Coins
  20. MarkusB
    4,215Coins
