Building a new 6DIY
Discussion in 'DIY Motion Simulator Projects' started by Flymen, Aug 22, 2018.
  1. Jeroen
    Jeroen DoctorXeno
    Holland
    - 70Coins
    Guess this is a joke?
  2. Flymen
    Montreal, Canada
    2,485Coins
    DC motor, 6DOF
    For a complet set up it's minimum 5000$
  3. Jeroen
    Jeroen DoctorXeno
    Holland
    - 70Coins
    Oh ok... I thought the question was for 1 actuator. Sorry...
    Very nice simulator you got there.
  4. Flymen
    Montreal, Canada
    2,485Coins
    DC motor, 6DOF
    Good news :grin:nerd !!!
    Finally , I found my problem . I must use two relay Opto 5vdc to control the drive and release the contact relay 24v and PSU 24 v . the response time is much faster like this !!
    • Winner Winner x 3
  5. hannibal
    hannibal Active Member
    4,492Coins
    now i see why @Flymen went for 30mm tube.. because the screwball thing is 28mm diameter!
  6. Flymen
    Montreal, Canada
    2,485Coins
    DC motor, 6DOF
    yes , you right !!!
  7. hannibal
    4,492Coins
    wow.. i thought it would be easy following wannabeflyer's genius diagrams.. (i am super grateful for his shares)
    a bunch of problems to solve, if the actuator is to be done correctly... im not keen on 3d printer parts for the load bearing parts... as i have seen people printed adapters to join 25mm OD tube to the 28mm OD ball screw...
    if i had known earlier, i would have went 30mm tube as well... but i think i might go the epoxy route.. :/ :/
  8. hannibal
    4,492Coins
    hey @Flymen what kind of material did you attach the bearings and ball screw nut housing? that plastic block material.. i like to know about it!
  9. Flymen
    Montreal, Canada
    2,485Coins
    DC motor, 6DOF
    yes , plastic PVC that was my last set up ! Now I have a New one !
  10. hannibal
    4,492Coins
    this photo.. was your old setup? any pics of your new method of linear guide?
  11. Flymen
    Montreal, Canada
    2,485Coins
    DC motor, 6DOF
  12. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    3DOF, DC motor, Arduino, 6DOF
    The link send us to a 80 volts? Aren't you gonna fry something? Usually, motor goes at 24v or 12v. Anyway, you know what you're doing. But then, you say 6 x 12 Volts. Maybe you don't know what your doing... :)
    I have 3 times 24 Volts / 12.5 Amps in parallele. I had no problem. No Diode or anything.
    I don't understand your regenerator problem with batteries.
  13. hannibal
    4,492Coins
    hey @Flymen i like to ask, what size bolts did you use to attach your Vslot aluminum rails to your plates? i plan to use M5 bolts, but i am trying to figure out what length the boths should be...
    asking @wannabeaflyer2 as well.. :)
  14. wannabeaflyer2
    london uk
    8,356Coins
    Hi @hannibal if memory serves me well I used Set screws with at least 20 - 25mm Threaded into the Extrusion . remember the plate you use will be a factor in screw length , so overall I allowed for Support Plate material thickness + 20mm minimum , that ensured that I had at least 20mm Of full thread contact in the extrusion.. Hope this helps ,
    It may be overkill with thread depth but would not hurt so what the heck :) that's what I used in my assemblies
  15. Flymen
    Montreal, Canada
    2,485Coins
    DC motor, 6DOF
    yes , 5mm was perfect for this without drilling and only tapping for me ! total length with v 30mm or 25 mm thread ! My plate have like 10 mm
  16. Flymen
    Montreal, Canada
    2,485Coins
    DC motor, 6DOF
    Temporary set up to access on the seat !!
  17. hannibal
    4,492Coins
    thank you!
    i mean most tap bits have about 25-35 mm of tapping distance.. i just felt that such a small length holds the actuator structure together.. especially with the load..
  18. BlazinH
    16,699Coins
    Does anyone know if brushless motors can even cause regen current? With no brushes even if it creates them I wouldn't think they could get back to the controller.
  19. hannibal
    4,492Coins
    amazing work @Flymen ! let see you ride that bad boy!
  20. Flymen
    Montreal, Canada
    2,485Coins
    DC motor, 6DOF
    @SilentChill , @SeatTime .
    I try to find more info for the gas strut than you had before !!Because my rig begin to be heavy and I'd like to have about 500rpm more and same time solver a small problem of regeneration .
    It a good idea or no ?
    Thanks for your help !
