Bourns 3590s 10 Turn Potentiometer
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by getti, Mar 7, 2019.
  1. getti
    getti Currently building my first 2dof seat mover...
    Canada
    45Coins
    I'm upgrading to Bourns 10 turn 10k. Is there anything special I need to do, software wise or other?
    About to start soldering.
    Arduino SMC3
  2. SilentChill
    20,590Coins
    I wouldn't use them they are terrible, they lasted about a week, if that on my rig. 10 turn hall effect pot will be what I may use next however they are a little expensive
  3. SilentChill
    20,590Coins
    Oh I see your on 2DOF with a worm gear ? you only need a 180 or 360 degree pot and I would highly recommend using the BT Tech Hall effect they are by far better choice
  4. getti
    Canada
    45Coins
    Oh ok, I wasn't expecting that. They look pretty good to me. Anyhow I already installed one so I think I'll just give it a go and see how they work. Is there anything I need to do inside simtools or SMC3 code?
  5. getti
    Canada
    45Coins
    Yes it's 3dof worm drive. The pots I've been using are in the picture on the right, cheap 10k 1 turn linear. I ordered these bourns not because they're 10 turn but because I'm hoping they're smoother, less jitter and last longer hopefully.
