Movement of Chair.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Hamreus, Mar 11, 2019.
  1. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    I need help and ideas what to use under the chair on a motion rig. I have this as on the picture. The problem is it’s to high. I need something that is like that but as low as possible.
  2. Nick Moxley
    You wont find a much shorter/smaller U joint than what you already have, maybe slightly shorter But why not modify the frame to suite the parts you have ?
  3. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    It’s too late. I then must rebuild everything. I want to lower the seat position. No room. That I have is for a tractor so it must be something smaller I hope.
  4. Nick Moxley
    Google "Flange U Joint" These style's are going to be the Shortest/Most compact/Durable joints your going to find.
  5. BlazinH
    16,676Coins
    It looks like that's what he has now. Mine is 3¼" tall and is the shortest I could find.
  6. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    3¼ tall is way lower than what I got. That would work perfect.
  7. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    Smaller I think you will not find, to reform the chassis would be a lot of work
  8. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    I got this
  9. zapata_h
    España
    308Coins
    It looks pretty solid, I think it would work fine
