Bug Game Engine crashes when iRacing starts
Discussion in 'SimTools DIY Version' started by FredBasset, Mar 10, 2019.
  1. FredBasset
    FredBasset Member Gold Contributor
    461Coins
    Hi folks, I've been happily using SimTools for a few months now with one of @SeatTime's harness tensioners. In the last couple of days a problem has developed though. Whenever I start iRacing Game Engine closes, there are no error messages it just closes itself down.
    Any ideas on what is wrong?
    Fred
  2. FredBasset
    461Coins
    Testing tonight shows that Sim Tools works fine with Asseto Corsa but crashes immediately iRacing starts.
    Does anyone else have this?
  3. yobuddy
    51,365Coins
    What version are you running buddy?
    Please try this, goto:
    C:\Users\(your user folder)\AppData\Local\SimTools\GameManager\GameProfiles
    Here you will have 2 folders 'LastUsed' and 'Profiles'.
    In 'LastUsed' delete the file for iRacing.
    In 'Profiles' delete the iRacing folder.
    Restart SimTools and give it another go!
    let me know how it goes,
  4. FredBasset
    461Coins
    version 2.3.1 and thanks that did the trick :) , what happens to cause that?
    Could I ask another question, since I've isntalled 2.3.1 it won't start with Windows despite it being set to do so.
    Thanks again
    Fred
  5. yobuddy
    51,365Coins
    Probably antivirus stuff?
    Not sure why it wouldn't i have not changed the code.
    It simply make a startup like in the startup folder is all.
    I can take a look if you cant get it working.
    Not sure, but i think I'll look at re-writing the profiling stuff next.
  6. FredBasset
    461Coins
    I deleted the shortcuts and recreated them, all fine now. Thanks for the help.
