SimTools Presets 6dof iracing axes assignments
Discussion in 'Game Engine axes presets' started by bruce stephen, Aug 21, 2016.
  1. bruce stephen
    general contractor
    michigan
    9,115Coins
  2. Denus304
    Denus304 Member
    600Coins
    Hi how do i load this preset?
  3. Thanos
    Electronics Engineer
    2,907Coins
    I'm not sure if this is for use with HEXPOD plugin...
    The HEXPOD plugin just needs to define the six axis in a single row, then it does the 6DOF mixing calculation internally...
    Just don't forget to use the traction loss axis (Extra3 in some games) instead of YAW.
  4. Gadget999
    12,156Coins
    Thanos - will the HEXPOD plugin work with the SMC3 controllers ?
  5. Thanos
    2,907Coins
    No, it has single com port output, where it sends all 6 axis data in single package.
  6. Gadget999
    12,156Coins
    ok - but it is possible to link the boards to send serial data to one another - so you have one serial connection
    if i program the boards to talk to one serial port is it possible to use this hexpod plugin ?
    where do you down load it ?
    do you have to install the actuators in an order 1-6 ?
  7. Thanos
    2,907Coins
    You will have to talk to the creator about this.
    You can download it here:
    http://90.187.72.145/hexpod/
    Thanos
  8. Gadget999
    12,156Coins
    who is the creator ? do they use this forum ?
  9. Thanos
    2,907Coins
    Yes, @hexpod
  10. Gadget999
    12,156Coins
    does this plugin allow a 6dof to simulate a different centre of gravity - ie a stewart platform ?
