Inside-out tracking Workaround
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by El_Batallitas, Mar 16, 2019.
  1. El_Batallitas
    El_Batallitas New Member Gold Contributor
    Spain
    37Coins
    Future VR headsets will have inside-out tracking which is not suitable for motion sims at first. I was thinking for a possible solution and I just came to this stupid idea: to create a body for the sim using cardboards.
    The sensors will detect walls and a ceiling, but those will be traveling with the sim. That should do the trick.
    This would open to a new world of customization, there is no limits to create a cool body for the sim, (does not necessary has to be cardboards) it could also have cool ventilation system and all...
    What do you think? is there some user with inside-out tracking system that could try this out? :)
  2. BlazinH
    16,671Coins
    Maybe if you paint a checkerboard pattern or something on the cardboard it would work. From Microsoft:
    The product has been designed to work in normal environments. Consider the following thought experiment - if you were in a completely blank room (white walls, white ceiling, white floor) then the tracking system would find no features to track and would fail. If you were in a room that was covered in art work and decoration, then the tracking system would find many features to track and would work well. For the most part, typically decorated homes and offices have been demonstrated to have sufficient feature detail to track well.
  3. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
    2DOF, 3DOF, AC motor, SCN5, SCN6, SimAxe, Motion platform, 4DOF
    The guys have a lot easier solution to your problem:
    1 - For the oculus - before starting the program of the oculus, simply close the sensors with any objects or unscrew them into the wall.
    2 - For HTC Vive - you need to buy and install an additional tracker on the simulator.
    3 - For Windows mixed reality - turn off seconds in settings.
  4. BlazinH
    16,671Coins
    I can't find this in Window mixed reality settings. Can you provide more details?
  5. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
    just turn off borders in settings
  6. BlazinH
    16,671Coins
    Okay thanks. I was looking in windows settings under mixed reality. I'm already running without borders.
  7. SilentChill
    20,595Coins
    What ????
  8. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Thats the worst response I have read in a while.
  9. SilentChill
    20,595Coins
    This is exactly what I was going to try when I got my Odyssey, and I have got my Odyssey and it works although it is very primitive how I have done it just to test. I am getting some sticky chequered vinyl which I will wrap round my platform with a couple of boards in front, hopefully it will work ok.
  10. SilentChill
    20,595Coins
    I think it may work if you enclose the whole rig, I couldn't get it to work right well I'm afraid after more testing. However it works great with a controler on the rig but vibrations and jerking becomes a serious issue. I will post a seperate thread for help :)
  11. BlazinH
    16,671Coins
  12. Trip Rodriguez
    Trip Rodriguez VR Pilot
    Lake Ariel, Pennsylvania
    3,977Coins
    Aren't these solutions (not including proper compensation with a controller or tracker on the platform) only going to correct the positional tracking? As far as I know rotational tracking* is by IMU on all these headsets, no?
    Pitch and roll I think are 100% IMU, yaw I think is IMU with drift correction via the optical tracking.
  13. SilentChill
    20,595Coins
    Yeah I tried it and it was terrible , it deffo does not work
  14. prime97
    prime97 New Member
    Sydney Australia
    143Coins
    Using an HP Reverb (inside-out tracking), I tried building a cardboard enclosure on my motion platform with various stripes on the inside of the cardboard for the headset camera to pick up. It was a big failure. The picture would jump and if I was driving around a corner then some of the jumps would put the horizontal at a sickening angle - I had to stop after less than 10 seconds. It gave the impression that the tracking system was seriously struggling to work out the orientation. It would seem that the gyros in the headset were outvoting the camera inputs. For this to work, the gyros would need to be disabled so that only the cameras are used.
  15. Phlames
    Phlames Member
    324Coins
    why cant a program just use the telemetry data to move the play space. that sounds like the easiest thing to do and it would work with every headset no matter what type of tracking you are using, light house, camera or inside out. Why wouldnt that just be what people make to work it seems like it shouldnt be to hard to make ( im not a programmer so sorry if it is). but maybe it just sounds easy and its really more complex than that. I do remember someone saying that oculus wont just let you change the floor or something like that maybe thats why its so hard to do and in that case you would think that the manufactures of each headset would make there own version of motion compensation being that the sim world spends so much money in this field.
  16. noorbeast
    152,535Coins
    +11,085 / 56 / -2
    In effect that is what motion cancellation does, moves the HMD view to account for and offset the rig movement, but it is not easy to do in low latency real time in a robust and cost effective manner. At the moment the approach to cover robust and cost effectiveness is via utilisation of Lighthouse tracking, here is the member driven efforts: https://www.xsimulator.net/community/threads/openvr-motioncompensation.14576/
  17. Phlames
    Phlames Member
    324Coins
    Thanks for the links i know about the light house tracking as that is what I currently have and will be using. I was just speaking more about getting it to be fully working with inside out tracking mainly.
  18. noorbeast
    152,535Coins
    +11,085 / 56 / -2
    No problem. Those working on motion cancellation are aware of the interest in conquering inside out tracking as well, but for now Lighthouse is the easiest supported way to go.
  19. Dschadu
    Dschadu Active Member
    1,936Coins
    Every SteamVR supported device works with motion compensation.
    The issue is the tracking itself. If the HMD tracking does not work reliable on its own, no software can compensate that.
    The tracking has to work on its own in the desired environment. If this works, you can start adding additional layers to it, like motion compensation. But if the tracking is wonky out of the box, there is no way to adjust for that in software.
  20. sci666
    1,220Coins
    so is there ANY way to do motion compensation with an inside out tracked HMD ???
    the only way i can imagine is to use one of the included controllers as a "tracker" wich is fixed to the rig.
    and then use it as reference point. is this possible or does steam VR motion cancellation plugins cant use the controllers as ref-point ?
