DIY FFB Steering wheel (MMosFFB ) (In Progress)
Discussion in 'DIY peripherals' started by Alexey, Dec 10, 2015.
  1. Sieben
    Sieben Active Member
    2,241Coins
    nopilpl, bay the way. Don't use "invert". Change the AB wires to arduino, with each other. Otherwise that will bring a mess with pwm signals. Don't know the encoder issue.
    Use separate 12vpower to encoder. There vere few pages later info on it.
  2. nopilpl
    nopilpl New Member
    213Coins
    It isn't encoder issue, beacuse i tested other software and it worked.
    I changed AB wires with each other, and I use 12v supply for encoder and it still doesn't work.
  3. nopilpl
    nopilpl New Member
    213Coins
    I changed Z phase with connection betwwen GND and 6 and it works now.
  4. Sieben
    2,241Coins
    Z toggle should be tasted long ago as was described it video guides.
    Don't use "invert". Change the AB wires to arduino, with each other. Otherwise that will bring a mess with pwm signals. That was mentioned not to that issue. You will understand that later on when will conect the motor drivers. If will use ebolz magi emc soft that toggling will not be required every time. With centering a wheel. And that's a very good soft.
  5. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Hello,do you have ebolz magi emc soft,he doesnt seem to sharing it anymore.Thank you.
  6. Sieben
    2,241Coins
  7. nopilpl
    nopilpl New Member
    213Coins
    I fix this problem but I have another.
    When i rotate my wheel to the left, the motor increase rpm, but when i rotate it right, it decrease rpm.
  8. nopilpl
    nopilpl New Member
    213Coins
    When i rotate wheel for example 900 degrees then egine tries to stop the wheel but, then engine stop working, and I need to restart it.
    Do you know why this happen?
  9. Sieben
    2,241Coins
    What is supply power? What motor are you using? Stall current of motor may be too high for bts with that motor.
  10. nopilpl
    nopilpl New Member
    213Coins
    12v, 8.5amp
    I AM using 12v 100watts DC motor
  11. Sieben
    2,241Coins
    Try paraller 2BTS together. Or even triple. And tell about results. Check the BS SIM thread.
    And other explanation on other videos.
  12. nopilpl
    nopilpl New Member
    213Coins
    I have only one vnh2sp30
  13. Sieben
    2,241Coins
    try to cool it down.
  14. Fernando Igor
    Fernando Igor Member
    Programmer
    Fortaleza, Brazil
    913Coins
    DC motor, Arduino
    Solved?
    You need to use pull down resistors on the channel outputs.
    Your encoder E6B2-CWZ5B PNP Open-collector Output Mode
    https://www.ia.omron.com/data_pdf/cat/e6b2-c_ds_e_6_1_csm491.pdf?id=487
    When the base is polarized, the output signal of the channels is undefined, so a pulldown resistor is needed (examples: 4.7k, 10k).
    Ebolz Magi shows a diagram in one of the videos.
  15. marybird
    marybird New Member
    88Coins
    guys i new to this field and i need your help
    can i use an 220v ac motor with ac motor driver ? because they are readily available and fairly cheap
    if it's possible please let me know
    also i found an epson stylus sx218 printer i want to get the encoder from it is it any good ?
  16. Onevia
    Onevia New Member
    - 3Coins
    DC motor
    Has anyone had experience using ibt-4 driver board? It turned out to be difficult to find a geniue ibt-2. I checked my local stores and all three had chinese fakes with half bridge ICs sanded down and remarked as BTS7960, even $15 ones.
  17. Lebois
    Math teacher
    2,559Coins
    220v ac motor : I guess the main problem will be to find a motor driver that will accept pwm signals and 220v ac power supply... I don't know any, and don't find any by googling a bit...
    Espon encoder : I would say it's a bad idea... You won't have the datasheet, meaning you will have a guess how to wire it, that isn't easy as it's digital signals. Then you don't even know what many ppr (pulse per revolution) you will have. If it's less than 500 (by example), it probably won't be enough to have a detailled ffb... By example, most dd wheel have 10000ppr encoders..
  18. Lebois
    Math teacher
    2,559Coins
    IBT4 seem to be limited to 15V right ?
  19. AguNicoGaby
    AguNicoGaby New Member
    68Coins
    2DOF, 3DOF, DC motor, SimAxe, SimforceGT, Motion platform, 4DOF
    WOW, estuve mirando un poco todo, y exelente proyecto!!! yo empeze con el mio, pero no logro hacer funcionar el encoder, actualmente estoy usando el encoder del g27, tiene 5 cables (negro,rojo,blanco,negro,amarillo,verde) alguien pudo hacer funcionar este encoder?
    En el ai wave 2016 (rfr wheel config) el volante queda girando en un solo sentido y no se calibra, uso pmw +dir y ppr 780
    A la espera de una respuesta, Saludos!
    WOW, I was looking at everything, and excellent project !!! I started with mine, but I can not make the encoder work, I am currently using the g27 encoder, it has 5 cables (black, red, white, black, yellow, green) could someone operate this encoder?
    In the ai wave 2016 (rfr wheel config) the steering wheel is rotating in one direction and is not calibrated, use pmw + dir and ppr 780
    Waiting for an answer, Regards!
  20. Fernando Igor
    Programmer
    Fortaleza, Brazil
    913Coins
    DC motor, Arduino
    https://prnt.sc/nknjbd
    Check it's the same model (tracks).
