Hall sensors, sabertooth 2x32. Slight lag/delay on one side
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Trigen, Mar 21, 2019.
  1. Trigen
    Trigen Active Member
    2,890Coins
    Hi guys
    Ive fitted some hall sensors and its working great! Its on a sabertooth 2x32
    My issue is that one side/motor is about a millisecond or two to react in comparison with the other. The wire length on one axis is a bit longer but at lightspeed that should not matter.
    Any experience with this? Hardware or software issue?
  2. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    Try swapping sabretooth motors and sensors, so you'll check if the problem is in the saber tooth or in the motors
  3. Trigen
    2,890Coins
    Deffo the B channel that is slower. Need to test the other sabertooth too so im sure its not a serial issue of some kind.
  4. BlazinH
    16,671Coins
    Check if the PID settings for both motors are the same. If one motor normally turns opposite of the other its not unusual for a motor to run a little better in one direction than the other. In any case that's what PID settings are for so try increasing P and/or I on the slower motor and/or decreasing them on the faster motor.
  5. Trigen
    2,890Coins
    Ga
    Gave it a test. No change. The motors does run the opposite way to each other but ive switched the channels around and tested it before and same issue but in reverse so its leaning to a HW issue. Basing it on milliseconds and sound card setup id probably estimate it to be above 8ms (incorrect in the OG post) later for the motor to get the signal/react. Like said though im going to give the other one the same test today once i got it all hooked up again
  6. zapata_h
    España
    308Coins
    If you have tried the other way around and the problem persists but in the other engine it is clear that it is HW problem
  7. Trigen
    2,890Coins
    Same issue on both sabertooths actually. Gonna take this up with them
  8. zapata_h
    España
    308Coins
    The truth is that it is a strange error
  9. Trigen
    2,890Coins
    Started thinking that i might be overloaded somehow and tried to play with the Fpid and reducing calculatins. That helped considerably. You'd think it could handle that but its only 2 wires. Had no such issue on cheap china motor controllers but they use 3 wires for each motor. in any case its very close to perfect and i doubt i will notice
    Might be what you meant first Blaze but i only did KP KD.
