simulateur 3 dof
Discussion in 'DIY Motion Simulator Projects' started by Boxy13, Mar 22, 2019.
  1. Boxy13
    Boxy13 New Member
    25Coins
    3DOF, Arduino
    Bonjour . je suis nouveau dans ce millieu et mon projet et de me faire un 3Dof avec moteur et arduino micro , mais quand je teste avec simtool , les moteur bouge dans tous les sens et j'arrive pas a mettre les bielle a plat , si quelqu'un a idee pour m'aider ca serait sympa ?
    152,307Coins
    +11,070 / 56 / -2
  3. Boxy13
    Boxy13 New Member
    25Coins
    3DOF, Arduino
    [QUOTE = "Boxy13, poste: membre 175614,: 32475"] Bonjour. je suis nouveau et millieu Dans CE Mon projet et de me faire un 3DOF avec moteur et micro arduino, je teste Mais Quand simtool Avec, les Bouge moteur Tous les sens la DANS et je arrive pas a les Bielle a Mettre plat, si quelqu » un un Idee verser ca me aider Serait sympa? [/ QUOTE]
    Hello . I am new in this millieu and my project and make me a 3Dof with micro engine and arduino, but when I test with simtool, the engine moves in all directions and I can not put the rods flat, if someone an idea to help me that would be nice?
  4. Boxy13
    Boxy13 New Member
    25Coins
    3DOF, Arduino
  5. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    have you connected the potentiometers correctly?
  6. Boxy13
    Boxy13 New Member
    25Coins
    3DOF, Arduino
    I do not think I was wrong in the potentiometer connections!
    GND 3 potentiometer: red wire
    5V 3 potentiometer: black wire
    A0, A1, A2: yellow wire potentiometre.jpg
  7. MarkusB
    4,215Coins
    Which motor controller and which Arduino software are you using? SMC3?
    And screenshots of your SimTools settings could be helpful.
  8. Boxy13
    Boxy13 New Member
    25Coins
    3DOF, Arduino
    I arduino micro and 3 motors "geared motor I think" I post photos. sorry but I have very little knowledge in that!
  9. zapata_h
    España
    308Coins
    Software SMC3?
  10. Boxy13
    Boxy13 New Member
    25Coins
    3DOF, Arduino
    My software is simtool.
    I do not know what SMC3 means
  11. zapata_h
    España
    308Coins
    SMC3 is the program that loads the arduino
  12. zapata_h
    España
    308Coins
    What program do you currently have in arduino?
  13. Boxy13
    Boxy13 New Member
    25Coins
    3DOF, Arduino
    Okay . I have already written, it's arduino Micro!
    SIMTOOLS 1_6_6 MOTORS 2x32_SERIAL_MICRO
    Give me an example of a program (I do not understand what you want to ask me)?
  14. zapata_h
    España
    308Coins
  15. MarkusB
    4,215Coins
    Well, an Arduino is a computer, and all computers need software. The term "program" means the software that you have loaded onto your Arduino. The Arduino language also calls it a "Sketch".
    Knowing which Arduino sketch you are using could help identifying the source of your problem.
    Also a wiring diagram of your setup could help, and - as I mentioned before - all your SimTools settings. You only provided part of the "Interface Settings", but the "Axis assignments" are still missing.
  16. Boxy13
    Boxy13 New Member
    25Coins
    3DOF, Arduino
    I found the problem, it works now
  17. zapata_h
    España
    308Coins
    Can we know what the problem was?
  18. Boxy13
    Boxy13 New Member
    25Coins
    3DOF, Arduino
    I think of a bad connection with interference
  19. zapata_h
    España
    308Coins
    Ok, if it's already solved much better
  20. Boxy13
    Boxy13 New Member
    25Coins
    3DOF, Arduino
    Hello I care about plugin with (Eurotruck 2, American truck and Nascar 14)
    The first 2 nothing moves and Nascar is in fact, Nascar 03
    If anyone has a solution to solve my problem?
    Thank you
    Bonjour j'ai souci de plugin avec ( Eurotruck 2, American truck et Nascar 14)
    Les 2 premiers rien ne bouge et Nascar est en fait , Nascar 03
    Si quelqu'un a une solution pour resolver mon probleme ?
    Merci
