resistor for sabertooth 2x32 - psu 24v 1000w - motor 24v 350W
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by gigi, Mar 28, 2019.
  1. gigi
    gigi Active Member
    912Coins
    2DOF, JRK, 4DOF
    Hallo,
    I have this configuration
    sabertooth 2x32 for n.2 motors 24v 350w 20,5Ah each . the PSU is 24v 1000W like meanwell.
    Can you please suggest a correct resistor to avoid that regenerative current bourn my psu?
    I asked to dimension enginering and they suggest at least resistor 200w 3 ohm
    In the sabertooth box ther are only 2 small resistor 10W and a resistor 200w 3 ohm is very expensive.
    Any suggestion?
    thanks for support
  2. Milani Fabio
    Milani Fabio Active Member
    Italia
    718Coins
    Hi Gigi, this is the link of the same subject discussion.
    https://www.xsimulator.net/community/threads/sabertooth-2x32-uno-rev3.12391/
    Same your problem, n. 3 engines and n. 2 power supplies with the same features for DOF 3.
    I purchased n. 6 metytere resistors in pairs in parallel of 6.8 ohms 100w.
    https://www.cariatielettronica.eu/1...100-watt-corpo-in-alluminio-100w-100watt.html
    Hello
    Fabio
  3. gigi
    gigi Active Member
    912Coins
    2DOF, JRK, 4DOF
  4. Milani Fabio
    Italia
    718Coins
    The 6 ohm resistense are hard to find, I don't know why.
    I'm not an electronics expert.
    The value that is closest is 6.8 ohms, I asked a store in my city and he told me that it's fine.
    Hello
  5. bixler13
    bixler13 Member
    107Coins
    Check car turn signal resistors as well. Here you can get a 2 pack of 50W 6 ohm resistors for $5 USD. Use standard series and parallel connections as required to get the correct resistance and power requirements.
  6. gigi
    gigi Active Member
    912Coins
    2DOF, JRK, 4DOF
    Hi bixler13, thanks for your post.
    I bought these:
    https://www.cariatielettronica.eu/1...100-watt-corpo-in-alluminio-100w-100watt.html.
    N°2 resistor 100w 6,8ohm each in parallel for each motor mean that total resistence is 200w 3,4 ohm. I also asked to dimenson enginering and they answered me that my choice is ok. For 4 motors I bought 8 resistors
  7. Mister_Ray
    Mister_Ray New Member Gold Contributor
    Deutschland
    66Coins
    I'm new here in the forum and would like to build a DOF as an experimental setup. I have 2 24 V motors with 440 W each and a Sabertooth 2x32. Now I'm looking for the right resistances. I calculated the resistor values on the website.
    If I understand correctly, I need 1.3 ohms per 440W motor. Then I have to, for example. 5 x 6.8 Ohm 100 W parallel to B + and P1 and 5 x 6.8 Ohm 100 W parallel to B + and P2
    connect.
    I've often read something as low as 8 amps, but 440W / 24V = 18.33A?
  8. Mister_Ray
    Deutschland
    66Coins
    I have now reread the instructions for the 2x32 again.
    If I understood correctly P1 and P2 power outputs which can each be loaded with 8A.
    But if I connect only 1.3 ohms at 24V between B + and P1, more than 8A would flow there.
    That would mean with 24V and 8A a 3Ohm 192W resistor would have to be installed?
    Then the resistance would be independent of the engine power, right?
  9. Milani Fabio
    Italia
    718Coins
    Regardless of the power of the motors, Sabertooth can discharge a maximum of 8A.
    I mounted 2 Sabertooth 2x32A with 4 350w 24v motors.
    I put these resistors and everything works fine.
  10. Mister_Ray
    Deutschland
    66Coins
    Thank you,
    for the quick reply. Since I stumbled across the 8A myself. I also considered the same structure with 2 6.8 Ohm 100W. The resistors are not that expensive in this size. Thank you for the picture with the structure makes it a little easier
  11. _cOdaC_
    _cOdaC_ Member
    245Coins
    I really like your design which fits my project quite well.
    Can you tell me something about the Wire Gauges?
    Which Gauge did you use for the following connections?
    - Motor to Sabertooth
    - Cables between the resistors
    - Cables to Power Supply
    - Cables to potentiometers
  12. gigi
    gigi Active Member
    912Coins
    2DOF, JRK, 4DOF
    Please excuse me if I am late in replying to your message. I abandoned that project a long time ago to move on to actuators. The thickness of the cables is very important only for connecting the motors to the Sabertoth boards. I don't remember the exact diameter, but I remember using the cables and connectors that are normally used to connect solar panels. Another important thing in my project was to place a heat sink on the boards and also a PC fan to cool them. In this way, even with intensive use, the cards remained at a temperature never higher than 40°. As regards the cables between the potentiometer and the board and between the resistor and the board, very thick cables are not necessary
