Game vibe setting help
Discussion in 'SimTools Plugins' started by Oxystrange, Mar 31, 2019.
  1. Oxystrange
    Oxystrange New Member
    65Coins
    Hi all
    First post so please be gentle on me
    Just trying to work out what sound pattern and frequencies to use in game vibe ive played around a bit but feels a little off.
    wondered if someone can share what theyre using for each effect
  2. yobuddy
    51,558Coins
  3. Oxystrange
    65Coins
    I have seen that, ive worked out the tuning center
    But cant find a good baseline for vibe creator most things seem set to sin or sqr wave between 30hz and 70hz and turbulence feels like i have a dentist drill up my butt i found setting it to brown wave at 80hz to 100hz is a bit better. Is there and auto tune or better setting that will cover this part
  4. yobuddy
    51,558Coins
    LOL, it really depends on what you have for equipment.
    So just playing around usually yields better results than copying someone else's settings.
    There is no reason you have to use 100% for anything either.
    Just make it feel go to you and your off to the races.
    Take care,
  5. flyingdingy
    flyingdingy Member
    IT
    Norway
    570Coins
    Old thread, I know, but I landed here searching for the same (some baseline / preset / presets settings people use for Game Vibe)
    As yobuddy writes, best to tune your own as i varies greatly on the hardware, positioning and so forth, but here is a guideline from ChatGPT that helps to point in the right direction:
