Tutorial Graphic SimTools parameter adjustment
Discussion in 'SimTools DIY Version' started by fzxj520, Sep 10, 2016.
  1. Wajdi
    Wajdi Member
    416Coins
    With my setup I wasn’t feeling the G force in breaking/acceleration and gear changing but I went to users/app/SimTools/Simengine/maxmin.... I edited the maxmin of Surge and Sway to 2/-2 and 1/-1 and woww... such a big difference. Now I can feel my body is thrown forward and backwards in braking and acceleration and now you can feel the gear change through the seat.
    I think that less range of movements but much more faster is better .
  2. marco balletta
    marco balletta Member
    1,445Coins
    When you switch gear, can you feel the changing of the gear from high gear to lower gear ( 6 to 1) ?
    I can feel when changing from 1 to 6 but not the opposite. The deceleration of the car takes over of the gear switch movements . Is it the same for you too?
  3. Wajdi
    Wajdi Member
    416Coins
    Yea, I fell it in up shifting and less in downshifting.
    Si, lo sento di più quanto cambio in alto ma quando scalo la marcia sento più l’effetto della frenata. Forse anche un limite del software SimTools? Chi lo sa.
    Cmq, io sono nuovo qui e devo ancora capire tante cose con questo SimTools.
  4. PAPICALOU
    PAPICALOU 2 DOF ARDUINO SABERTOOTH SIMTOOLS Gold Contributor
    79Coins
    Good evening
    Why are my 2 '2 DOF' motors moving correctly in test mode
    As soon as I put a game it's a hassle.
    On LFS nothing is moving
    On ASSETO it moves anyhow
    Can you help me
    152,971Coins
    +11,115 / 56 / -2
