value1
IL-2 Sturmovik: Battle of Stalingrad plugin 2.0.0.5
SimTools game plugin for IL -2 Sturmovik "Battle of Stalingrad"
  1. value1
    14,236Coins
    • Winner Winner x 6
    153,710Coins
    After all the drama to convince the devs it is great to have IL2 BOS motion. I am about to go traveling overseas but I hope others can create an post so awesome videos, as that may encourage other devs to actually get behind APIs for motion simulation.
    • Agree Agree x 3
  3. Jörg Ziegler
    Jörg Ziegler New Member Gold Contributor
    191Coins
    SCN5, SCN6, Motion platform, 4DOF
    I want to thank value1 for making the great plugin so quickly and making my dream come true!
    I have a small video, nothing fancy, just a prove that it works....
    I have a question @value1 what does the SURGE exactly do here in the plugin? And where and how do I connect it?
    Was bewirkt der Surge Effekt eigentlich in IL-2 und zu welchem Aktuator soll ich es am besten zuordnen?
    I am still working on my Simtools profile.
    Thanks so much, best regards
    Joerg
  4. value1
    14,236Coins
    Well, when flying you will also feel braking and acceleration. Probably for even longer than when racing. This might be an issue, because you cannot mimic such long times typically with a simulator. Try pitching the seat up or down to see, if it feels like acceleration. At the end, it's a matter of tweaking your profile until it feels "natural" for you in your seat/platform.
  5. Jörg Ziegler
    191Coins
    Hello Thomas,
    thank you for your help, I will continue testing and tweaking.
    Gruß Jörg
  6. Jörg Ziegler
    191Coins
    Hello Thomas,
    just want to provide feedback after some more testing.
    I took out surge in my profile and activated sway instead, actually I did not feel anything.
    I am not sure what sway will do!? In sim racing sway will provide G force feeling, here I did not feel anything.....and no surge effect after I put in sway.
    Did anybody else here try the IL-2 plugin already? I get pitch, roll and yaw effects. Heave and surge is missing for me so far.
    Thanks and best regards Joerg
  7. Piotr Janta
    Piotr Janta New Member
    Poland
    18Coins
    2DOF, SCN6
    cant get this plugin to work - I have prosimu 2 dof ( newbe) but only AC , Dir Rally and PC 2 Imanged to work
    IL 2 and ED no luck so far, anyone can show me how to setup sim tools for that game??
    153,710Coins
    You need to patch the game for motion in Game Manager and then create and refine a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  9. Leandro Kemp
    Brasil
    - 10Coins
    Hi.
    My IL2 Battle of Stalingrad Blitz Edition Steam did not work.
    I did the patch. Game Running appears, but does not move any axis.
    Do I need to do anything in the game settings?
  10. Piotr Janta
    Poland
    18Coins
    2DOF, SCN6
    Thanks for tip but this plugin its not working for me. I have non steam edition ( & all DLCs) with 3d migoto mod .Maybe this mod generating issue with this plugin ? But I cant flying without it in VR.
    I resolved my Elite issue with plugin and so only Il 2 its not working.
  11. Leandro Kemp
    Brasil
    - 10Coins
    I've done all the profile settings and it still does not work.
    When I leave the game, an error message appears.
    Vídeo
  12. value1
    14,236Coins
    You might need to change a config file manually. I'll let you know when I'm back online.
  13. yobuddy
    51,521Coins
    @Leandro Kemp,
    Sounds like all your interfaces are crashing on startup.
    (you hear all those beeps?)
    Is your hardware turned on?
  14. Leandro Kemp
    Brasil
    - 10Coins
    Yes, everything is OK. I clicked it several times on the off.
  15. value1
    14,236Coins
    There should be a file called startup.cfg in your installation directory.
    Add the lines
    Code:
    [KEY = motiondevice]
       addr = "127.0.0.1"
       decimation = 2
       enable = true
       port = 4321
    [END]
  16. Piotr Janta
    Poland
    18Coins
    2DOF, SCN6
    its possible to add extra port to this line ?
    I have Gametrix jet Seat pad open that way in IL at port 29373
    how to write this in your code ?
  17. Leandro Kemp
    Brasil
    - 10Coins
    It worked.
    Thank you.
  18. Jörg Ziegler
    191Coins
    Sorry for my late reply here, I didn't check for a while.
    Does IL-2 motion work now for everybody here? How is YOUR experience with the motion in IL-2?
    I did not test my motion rig for a while now, because my job keeps me too busy. MY experience was so so.
    For "normal" flying like an airliner or a Cessna 172 would do.....I mean pitch and bank angles in moderate and normal limits it feels great, BUT flying like a combat plane with very high pitch and bank angles and doing aerobatics my experience is not that great with IL-2 and motion....MY motion rig is very limited in pitch and bank angles and in aerobatics it does not work that great for me.
    How is YOUR experience?
    Thanks Joerg
  19. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,838Coins
    DC motor, 6DOF
  20. hexpod
    berlin
    7,838Coins
    DC motor, 6DOF
    As I played around with this title veeeery long time ago, I am not sure which version of the game it concerns.
    Could someone point from where we can buy a non-steam version?
