would it make a better arduino interface?
Discussion in 'SimTools compatible interfaces' started by ferslash, Jan 25, 2019.
  1. ferslash
    ferslash Active Member
    4,798Coins
    https://www.sparkfun.com/products/14812?utm_campaign=January 25, 2019&utm_source=hs_email&utm_medium=email&utm_content=69294066&_hsenc=p2ANqtz-9z__2Hv6n4F-E4GJ_biPMjfCKav5CdoGBtWLHVUwiw1Wb3AkXN5A5Q-rEHNGmTQVEShfApkoUWhBueK9WfUYdCY7KurA&_hsmi=69294175
    It has been discoused that arduino interfaces are not as "good" as jrk12v12, that arduino lack of "smothines" when moving the motors, and somebody told me that it is related among other things to the speed of arduino... i wonder if his board would make arduino interfaces smother?
    it says the board is super fast compared to an arduino with 8 bits
    what do you think?
  2. Gadget999
    12,072Coins
    The Arduino is plenty fast enough
    Its analogue output has a resolution of 255 steps
    So there are 255 positions the actuator can be in
    For a simulator this is probably enough resolution, it is not like we are building a cnc machine !
    The std arduino has 8 bit resolution 255 steps
    There are versions of arduino that have more resolution
    The due has a resolution of 4095
    The zero has a resolution of 1023
    Use the map function to adjust to the new resolution
  3. BlazinH
    16,676Coins
    I have no idea what you're talking about :confused:. Care to elaborate?
  4. BlazinH
    16,676Coins
    Don't believe everything you read or have been told.
  5. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    Arduino one is enough to use in 2DOF, as the partner says there are arduinos with more resolution than the arduino one, the more resolutions the greater number of steps will have
  6. SeatTime
    Please read the documentation on this page...https://store.arduino.cc/usa/arduino-uno-rev3 Eg. 'The Uno has 6 analog inputs, labeled A0 through A5, each of which provide 10 bits of resolution (i.e. 1024 different values).'
  7. zapata_h
    España
    308Coins
    What the partner refers to is the PWM output, which handles values of 0-255
  8. ferslash
    4,798Coins
    thanks guys :D:D:D
  9. zapata_h
    España
    308Coins
    nothing, what you need
