Question SimXperience GS4 seat. Can SimTools run this hardware?
Discussion in 'Commercial Simulators and Peripherie' started by MAYAman, Jan 15, 2019.
  1. MAYAman
    MAYAman New Member
    97Coins
    Firstly apologies for the noob question but I have been asking other sim racing friends and no one knows. I have a GS4 seat and would like to experiment adding more motors and paddles of different sizes. I’ve moved all the hardware to a proper racing seat but want to explore adding more.
    Is there a way I can use the GS4 motors/power supply/circuit board with Xsim? What would I need to do to add more panels? I’m a total virgin with X-Sim so please be gentle. :)
  2. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    https://www.xsimulator.net/community/threads/simtools-and-simxperience-gs-4.7050/
  3. MAYAman
    MAYAman New Member
    97Coins
  4. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    I don't have a GS-4, but I am sure there was several members here who would like to see photos of your mod :)
  5. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,442Coins
    AC motor, 6DOF
    I am not 100% sure what you are trying to do. But I have built a DIY type GS-4 using a Arduino board and high power 24volt servos.
    https://www.xsimulator.net/community/threads/g-seat-where-to-start.12770/
    If you are just needing to add additional servos (HS-805) you can simply use a heavy duty Y connector. Many vendors sell them here is an example. You will need heavy duty which means 22 gauge wire.
    https://www.ebay.com/i/192079411463?chn=ps
    If you want to use x sim you will have to ditch the Simexperience control box.
    Then use a $10 arduino uno to control the servos. The meanwell power supply is reusable. The drawback is the mass of wires / rewire you will need.
    more than willing to help:cheers
  6. MAYAman
    MAYAman New Member
    97Coins
    ^^^That is exactly what I needed. Thanks! When I’m done I’ll post pics.
  7. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    331Coins
    The servo control center board does not allow more than 16 servos Will as far as i know.
  8. MAYAman
    MAYAman New Member
    97Coins
    Thanks Henk,
    Do you know of better motors? I know you upgraded your seat. Could you PM me?
