Problem with 3DOF H3 simulator
Discussion in 'Commercial Simulators and Peripherie' started by Vedran Guculj, Apr 8, 2019.
  1. Vedran Guculj
    Vedran Guculj New Member
    169Coins
    Hello!
    I bought dis rig 2 weeks ago and since then i managed to fly only once in DCS! Last thing that i did is that i put preset from zip file into the preset installer and after that di rig is moving by himself when the game is on. I checked the output testing and everything looks fine! Any suggestions how to fix it?
    153,770Coins
    +11,149 / 57 / -2
    There is not enough detailed information, please post pictures of all of your settings.
  3. Vedran Guculj
    169Coins
  4. Vedran Guculj
    169Coins
  5. Vedran Guculj
    169Coins
    153,770Coins
    +11,149 / 57 / -2
  7. Vedran Guculj
    169Coins
  8. Vedran Guculj
    169Coins
    This is siting on the airfield with egines off.....
    153,770Coins
    +11,149 / 57 / -2
    Have you captured the max and min like I suggested?
  10. Vedran Guculj
    169Coins
    Sorry if I bother you but i dont understand what i ned to do! When I open tuning centar and i want to change numbers i can't, the numbers inside the column are going up and down every time i press reset button .... I'm probably doing something wrong ...
  11. Vedran Guculj
    169Coins
    Hello, me again!
    I manage to resolve the problem, at saturday Oculus put on server big update regarding visual polishing and after that the problems started! Today after i have roll back pc history to saturday settings before problem occurred.Now everything is fine, working like charm.... Thx for everything and your efforts to resolve my problem! :cheers
  12. Vedran Guculj
    169Coins
    Hello again!
    Is the 3dof reality simulator prepared to be played immediately after installation, or additional mechanical adjustments are required?
    Both roll motors like to have 1cm of free space and when I sit in the seat the whole simulator is rocking!Do you need to set the motor pull arms rods, or are they already set? When it comes to roll, it is felt that the engines do not have a constant, rather than shake the entire construction!
