Question Too much lash on motor shaft ?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Arazok, Apr 9, 2019.
  1. Arazok
    Arazok Member
    Computer scientist
    783Coins
  2. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,784Coins
    All wormgears have backlash some more than others
  3. bixler13
    bixler13 Member
    107Coins
    I have the same problem with my setup. I fixed it by using bungee cords to keep pressure on the levers at all times in order to keep them on one side of the backlash.
  4. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Can you make a photo ?
    Would be good to see your solution.
  5. bixler13
    bixler13 Member
    107Coins
    You can see the bungee cords in the following picture. They simply pull the back end of the seat down which in turn keeps pressure on the levers and keeps them on one end of the backlash.
  6. Marc Lindgren
    Marc Lindgren New Member
    R & D
    Pennsylvania
    70Coins
    Backlash is experienced when the motor changes direction, so I'm not understanding how this would help that. Could you explain?
  7. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    by adding bungee cords to pull down and stop backlash you add to the amount of torque needed to lift the rear of the sim. surely the weight of a person sitting on the sim is enough to keep the backlash to a minimum like the bungees do with out adding to the torque needed to turn the motor. all wormgear motors have some backlash or they would be so tight they would wear the gears super quick or a tiny amount of debris would jam the gears and stop the motor. just my opinion but hope it helps
