Canopy screen rear projection
Discussion in 'Commercial Simulators and Peripherie' started by wannabeaflyer, Jul 30, 2009.
  1. wannabeaflyer
    wannabeaflyer Active Member
    UK - London area
    973Coins
  2. Amput
    Amput New Member
    Czech republic
    0Coins
    It looks like half of big cover (radom) wireless antenna :), but price 863€ is crazy.
    Size of CanopySCREEN
    Width of arch part 100cm
    Flat edge of width 5cm
    Overall width 110cm
    Length of arch 50cm
    Height 27cm
    Look at this http://www.jdome.com....2500€ crazy too :)
  3. wannabeaflyer
    UK - London area
    973Coins
    does anyone out there know the principle behind either of these products ?? one is back projected but thats where the magic starts the other may be a short throw projector ?? any takers ?
  4. Amput
    Amput New Member
    Czech republic
    0Coins
  5. wannabeaflyer
    UK - London area
    973Coins
    wow big thanks Amput for the pictures .. i take it that the projector is short throw ? is there a link to this post or website ?
  6. Amput
    Amput New Member
    Czech republic
    0Coins
  7. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    I found this http://thinkoutofbox.com/index.html (1440$ witout projector), so i start looking for mirror if i can get it cheper, luckily i found manufacturer (near my town :D) that sell this http://www.atop.cz/foto_004.htm (quarter ball, 100 cm diameter ) for 105E (150$). That would be great replace for FREX canopy screen if we paint it. Bigger problem would be get small mirror (they only do 60 cm diameter :( )
  8. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    Every time when i see some advert about any type of curved screens i am pretty sure that even those who are making them doesn`t know how they works.
    Thats what they trying to tell you is that you will be able to see more from the space before you, because of extra view what you will get on the left and right side (even up and down). You are not going to get Any Extra - you will only get illusion of the left and right size (usually corner of your eyes) which you had just flat on the screen before. Curved screen is not changing resolution of a screen it is only giving you same picture what you had on a monitor but in nice surrounded you atmosphere. Only that illusion, given you buy bigger screen and picture around you is worth to purchase this type of screen.
    Do not be confused by adverts about wider field of view because it is not gonna happed - projector is throwing his own resolution which is usually smaller (around 1240 x 720) than that on any monitors and canopy or any other screen is not going to change that (it`s technology not miracles).
  9. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    Nobody say that, i would like to try it becouse it must get you great impression and it could be better than monitors on whole moving sim.
  10. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    On the last picture Amput showed you advert from jDome screen - you can easy see that they trying to put you in the head an idea about larger field of view. Thats what is on the flat monitor doesn`t match projection on canopy screen. I have a question to them - why that is some kind of drawing not original picture. Actually i have seen a movie advert from jDome and they did the same thing - first showing you LCD picture and then some of the canopy screen but nothing about showing them together in action.
    Ones again - by crappy projector you are going to get less on the screen then on LCD or TFT. Consider TripleHead2Go. why this is giving you extra field of view - because it works in three times bigger resolution!
  11. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    With render of jDome i can see what you mean (the crane), but i dont argue with you i know you have right and i dont expect from that larger field of view, just better immersion int the game.
    Today it isnt problem build FullHD projector.
  12. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    I agree with that immersion. It is worth to invest in such screen. But...
    I will give you another point - it is about just curved screen. Ours perception in most of cases depends on horizontal view (less vertical). Why to not get really good FullHD projector with extremely bended screen or just like MasterYoda did with TripleHead2Go and tree projectors. They can be cheep ones (HD Ready only) but when connected together you are getting multiplied horizontal resolution! Which is even bigger horizontally than FullHD (smaller vertically but it is always something - Less...).
  13. njracer
    njracer Member
    2Coins
    we might be able to make a canopy screen. if we can find a transparent plastic and have it molded into the screen shape that we want, we'll be able to apply this http://www.theaterthings.com/store/proj ... tegory.asp to it and turn it into a projection screen.
    if enough people are interested, we might be able to get a discount when we get the plastic molded. any of you guys know a spot that will mold plastic?
  14. Mambo
    Mambo New Member
    Czech Republic
    288Coins
  15. CXCSimulations
    CXCSimulations Member
    - 9Coins
    Polycarbonate makes for a great optical grade thermoplastic. I'd be interested to see how that works.....
    I even have a fantastic vacuum form vendor I can recommend. I will tell you though, the mold prices are what kill you.
    The mind reels with possibilities though.
    Perhaps a great 1080p projector like this one: http://www.engadget.com/2009/09/09/mits ... for-1-395/
    And this software to fix the distortion: http://immersaview.com/sol7.html
    would be just the ticket
  16. njracer
    njracer Member
    2Coins
    yeah that looks awesome Chris, how much we talking for the molds?? its that outrageous??
    maybe we can come up with something ourselves make the plastic screen?? i have to look into how they do it
    hey Chris can we provide our own mold for the project?? what i'm thinking is getting a big beach ball and molding fiberglass or something to it to make the mold. seems like the frex canopy screen is a quarter of a sphere or egg shape, if we applied fiberglass or something to that portion of the beach ball we'd have our mold. if fiberglass isn't suitable for the mold, we can take that fiberglass shell and make a mold out of green sand and metal cast a new mold out of aluminum, what you think? possible to make our own mold for the plastic guy??
    btw Chris, have you looked at this projector?? http://www.depthq.com/projector.html its $6,000.00 right now but you know prices will come down soon enough and its 3d ready. can you imagine playing with this on a curved screen?? i think it would be sick granted the sim works well in 3d, but it seems nvidia gave most all the sims excellent score when using their 3d, but from what i've seen, you can't always go by their rating.
  17. Mambo
    Mambo New Member
    Czech Republic
    288Coins
  18. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,784Coins
    HI NJRACER
    In my shet i'm making recunbents for years now.
    And have something for you that's not gone kill you
    Look @ www.wisil.recumbents.com
    build/tech---hpv design----how to make blown fairings.
    I have seen the proces once, and it's so easy to do
    Make two at one time,and saw a streat line to center.
    Regards Ad
  19. ebinary
    ebinary New Member
    2Coins
    just remember that if you are rear-projecting on a dome the distance-the-light-travels is different for every pixel. That makes focusing and intensity very difficult. If you front project on a dome (which I am doing), the distance-the-light-travels can be more consistent than projecting on a flat screen (depending on the curvature). I bounce off a convex mirror in front of the dome, just above your feet.
  20. njracer
    njracer Member
    2Coins
    thanks for the info guys, definitely gonna give this a try, have a lot on my plate this month so i'll hopefully start this project early next month. hope all goes well :D
