Question U Joint
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Garrett Jones, Apr 17, 2019.
  1. Garrett Jones
    Garrett Jones New Member
    Melbourne, FL
    152Coins
    I'm intending to build a 2 DOF full frame motion sim. The only aspect of the build I have some uncertainties about is the u-joint. Where is the best place to get one, and what is a rough estimate on how much it will cost?
    Thanks!
    152,676Coins
    +11,088 / 56 / -2
    The cheapest option is to get get an old car tailshaft and cut the u-joint flange off and weld a mount plate to it.
  3. Historiker
    9,208Coins
    I have an extra, I will PM you.
  4. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    I used the u joint from the adjustable height steering column from a Peugeot 206 that was at the local scrap yard. its a lot smaller than a drive shaft u joint and wouldn't of had the same amount of forces put upon it and is usually a lot cleaner once removed and has 40mm of height adjustment built in IMG_0014.JPG . the downside is that its far more difficult to remove than a drive shaft and you will probably have to pay for the whole steering column but id guess that the breaker wouldn't sell many so u might get it quite cheep. I welded mine direct to the base and seat frame to keep the height to a minimum. my height from base to seat frame is about 120mm
  5. 427Cobra
    427Cobra There is no substitute for cubic inches
    Sweden
    567Coins
    I have also thought about using an u joint from a steering column but is it stable enough and can it handle the load?
    There are different sizes but all are much smaller than a u joint from a driwe shaft.
