2DOF Racing Simulator for Playstation
Discussion in 'DIY Motion Simulator Projects' started by Jakob Carron, Mar 19, 2019.
  1. Jakob Carron
    Jakob Carron Member
    34Coins
    unnamed (1).jpg unnamed (2).jpg unnamed (5).jpg unnamed (6).jpg unnamed (7).jpg unnamed (3).jpg unnamed (1).jpg unnamed (2).jpg unnamed (5).jpg unnamed (6).jpg unnamed (7).jpg unnamed (3).jpg Im making a racing simulator for school and I am making this thread so I am eligible for a DIY version of sim tools. Any feedback is still appreciated though.
  2. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    Step by step and with the help of the forum partners you will get it, encourage
  3. morsilli
    morsilli New Member
    96Coins
    3DOF, Arduino
    hello!
    rigidity is good? did you calculate the gravity center ?
    what kind of motors will you use for this project?
    good luck!
  4. zapata_h
    España
    308Coins
    The support the steering wheel at first sight seems fragile, perhaps need some reinforcement
  5. Jakob Carron
    Jakob Carron Member
    34Coins
    I will keep all of your suggestions in mind but does anyone know what else I need right now to get accepted for the code?
  6. Jakob Carron
    Jakob Carron Member
    34Coins
    I am using 2 Uxcell 24v Wormgear motors powered by 2 12v hp-460 12v power supplies that I have converted
    153,703Coins
    If you mean a SimTools DIY license key then this is the eligibility criteria:
    To qualify for a free license:
    • You must be building a true DIY motion simulator. (Not built from a kit or purchased from a simulator seller, a model simulator does not qualify.)
    • Have a unique build thread or Showcase in DIY Simulator Projects. (The thread should show some effort, which means it should show progress to the testing phase.)
    • Have been a member of the community for at least 30 days.
  8. Jakob Carron
    Jakob Carron Member
    34Coins
    What is the testing phase?
  9. zapata_h
    España
    308Coins
    The requirement is to attach photos of your assembly until you get the time to test the electronics are simtools
  10. Jakob Carron
    Jakob Carron Member
    34Coins
    Thank you
  11. zapata_h
    España
    308Coins
    Anytime, this forum always provides help
  12. Jakob Carron
    Jakob Carron Member
    34Coins
    I am starting the testing phase finally. I am using smc3 and ibt-2 drivers with an arduino
  13. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    like other users have mentioned already did you check the centre of gravity with the seat, pedals, steering wheel and most importantly you on it. It looks in the pic like the universal joint should be under the seat probably slightly forward of centre of the seat base. as it is at the rear of the seat your motors are going to have to work very hard to hold position so the drivers are going to get unnecessarily hot in my opinion. More heat = more cooling and wasted power from the power supply, you might want to check this
    looking good so far but might want to beef it up a bit for stability, if u get the universal joint right adding extra weight to make it more sturdy wont matter in overall sim performance from what you have now in the pic. should improve it but just my opinion
    hope this helps
  14. Jakob Carron
    Jakob Carron Member
    34Coins
    I did end up finding the center of gravity after and moved the U-Joint
  15. Jakob Carron
    Jakob Carron Member
    34Coins
    As you can see I am running smc3 and yes the wires are very disorganized but I followed the exact wiring diagram in the smc3 tutorial for the ibt-2. When i go to turn up the PWMmax nothing happens. It could be a wiring problem because I'm no professional as you can see by the picture of my wiring, but this is my second try with this because it didn't work before so I re soldered and rewired it all and the same problems are happening. Is there anyone else that has ever had this problem? Also its been a while since i worked on this project which is why there is a 2 year gap in this but I have picked it back up lol. Any help is appreciated thanks
  16. Christian Doehl
    Christian Doehl Member Gold Contributor
    Germany - Bavaria
    702Coins
    Hi Jacob,
    this is a post of mine where I explained the usage of SMC3 step by step.
    You can also look at my build thread as I also started with PS4.
    https://www.xsimulator.net/community/threads/starting-my-first-2dof-diy-motion-rig.15426/
    BR Chris
  17. Jakob Carron
    Jakob Carron Member
    34Coins
  18. Jakob Carron
    Jakob Carron Member
    34Coins
