Recommendations on a 3d Printer ?
Discussion in '3D Printing' started by Gadget999, Dec 16, 2018.
  1. Gadget999
    12,132Coins
    Hi guys,
    Thinking of buying a 3d printer. Will probably get a lot of use on a sim build
    Do you have any recommendations ?
    I have no clue what is good and not good
    Thanks in advance
  2. woodzie
    woodzie New Member
    167Coins
    I have a flash forge creator pro. Its been working for 3 years without problems, other than maintenance which is a pain to disassemble/ reaseamble.
    I use replicator G for my G-code. other programs cause problems with their start sequence and replicator G does its job.
    I use 123D design for my 3D modeling
    export as .stl
    open in replicator G and setup for printing
    All I can say is its still working fine and I can buy parts for it. Print quality is good @ 0.2 MM resolution but who knows whats out there now.
  3. Gadget999
    12,132Coins
    they can be bought for around £600 which seems like a good deal for an enclosed printer
    there are plenty of cheap kits but i dont really want to be wasting time building a printer - i want the printer building parts for a sim !
  4. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Prusa MK2 still very good and affordable 3D printer and the newer MK3 should be even better with more useful functions like removable bed sheet, filament sensors etc.
  5. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    The Creality Ender 3 Pro works well, and is as cheap as chips. I'm going to order the glass bed as well.
    • Agree Agree x 4
  6. Meng
    Meng New Member
    114Coins
    Formlab3, 打印很精准,DIY用足够了
    Google translate:
    Formlab3, printing is very accurate, DIY is enough
  7. Goatboy
    Goatboy Member
    New South Wales, Australia
    386Coins
    An enclosed printer is only important if you want to print ABS, personally I only print PLA & PETG currently so enclosed isn't important.
    I've got a Tevo Tarantula & Creality Ender 3 Pro, can say the Ender 3 is a very nice unit for it's price. If you want something with a bigger build platform the CR-10 is a very popular model.
    • Optimistic Optimistic x 1
  8. gingercat
    gingercat New Member
    Software Engineer
    Nr Lancaster, UK
    131Coins
    DC motor, SimAxe, Arduino
    I've got an Ender 3 Pro, upgraded to borosilicate (glass) bed, and with a raspberry pi connected running OctoPrint, so you can print over wifi. You can afford two of them for the price of the big name printers! The microSD-card reader is pretty terrible on it (hence adding the raspberry pi), but I think that's a common problem with Cura based printers.
  9. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    I purchased an anet a8 printer on amazon for £107 4 weeks ago to print various parts for my sim. it works good if you set it up properly and made a good job of assembling it. printed many parts with ok results but some of those parts have been upgrades to the printer itself to improve print quality. still good for the money though.
  10. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    540Coins
    Motion platform, 6DOF
    Hello, I bought a BIBO 2 Touch for 800 € on Amazon. They have very good support which helps a lot, especially in the beginning. Have all the parts printed with it for my ring in PETG.
  11. ghidossi
    ghidossi Member
    - 12Coins
    3DOF, Arduino
    Hi, I build my own printer with arduino and it's complicate to calibrate. So if it's only for few part maybe you can go in a store or a fablab to print all.
    Regards
  12. mream
    mream New Member
    13Coins
    Check your local Meetup groups for 3D printing, colleges, and libraries. They very often have access to 3D printers you can use without needing to purchase your own. Unless you're intending to print all the time..
  13. FelfelX
    FelfelX New Member
    198Coins
    I personally use the Photon by Anycubic resin 3d printer. Unbeatable value although the print area is relatively small but being a resin printer the parts are really strong
  14. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    I currently have the Anycubic Kossel delta Plus, had to flash new firmware except for that it is an excellent printer good quality prints at higher speeds printed quite a few parts for my 2 Dof motion ring on it.
  15. getti
    getti Currently building my first 2dof seat mover...
    Canada
    45Coins
    Ender 3, cheap and awesome! Check out the Amstudio youtube channel for a great review of Ender 3 and other awesome DIY sim racing kit.
  16. getti
    Canada
    45Coins
  17. lysa elec
    lysa elec LYSA ELEC
    16Coins
    thanks for fhis informations
    i try ultimaker 2
  18. lysa elec
    lysa elec LYSA ELEC
    16Coins
    is enyboby use ultimaker 2 with carbone fil ?
  19. lysa elec
    lysa elec LYSA ELEC
    16Coins
    ultimaker 2 is a very good printing 3D
  20. jeanmehdi
    jeanmehdi New Member
    LONDON
    - 201Coins
    I just got myself an Anicubic i3 Mega and loving it so far
